Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 9 of 9
  1. #1
    Senior Tech 1,000+ Posts kuby's Avatar
    Join Date
    Oct 2007
    Location
    Texas
    1,270
    Rep Power
    54
    Ecosys M2540dw - parallel adjustment ?
    Is there a parallelogram image adjustment for this printer? Copies from glass and DF come out shewed - out of parallel. Tried making sure the paper cassette was OK, no help. This is a new machine. some pages worst than others but it is always there. More noticeable on full page scans, look at the bottom and tops. Usually off 2 - 3 mm.
    Checked the scanner carriage - OK. Checked paper tray - OK.
    Attached Files Attached Files
  2. #2
    Field Supervisor 500+ Posts Geo's Avatar
    Join Date
    Nov 2010
    661
    Rep Power
    38
    Re: Ecosys M2540dw - parallel adjustment ?
    Quote Originally Posted by kuby View Post
    How are the internal prints ? Any difference from the MPT?
  3. #3
    Join Date
    Oct 2007
    Location
    Texas
    1,270
    Rep Power
    54
    The sample page is a internal print.
  4. #4
    Senior Tech 100+ Posts
    Join Date
    Feb 2018
    Location
    Orlando, Fl
    161
    Rep Power
    15
    Nothing found in manuals, bulletins, QA's or on Astea but the only thing that comes to mind off hand is the scanner lamp ass'y. Is it square to the scanner frame or has it been jarred slightly askew?
  5. #5
    Join Date
    Oct 2007
    Location
    Texas
    1,270
    Rep Power
    54
    Scanner looks fine and is seated correctly and moves freely. This is a replacement for the other one we ordered because the first one was doing the same thing.
  6. #6
    Join Date
    Nov 2010
    661
    Rep Power
    38
    If internal prints are skewed , then you can eliminate the scanner or glass they don't come into play when doing an internal print..
  7. #7
    Senior Tech 250+ Posts
    Join Date
    Aug 2008
    Location
    Seattle
    284
    Rep Power
    41
    Any success at straightening the crooked images? I'm noticing the same symptom with multiple machines.
  8. #8
    Master Of The Obvious 10,000+ Posts
    blackcat4866's Avatar
    Join Date
    Jul 2007
    Location
    Lapeer, Michigan
    22,469
    Rep Power
    463
    It's got to be a paper skew if it's happening on internal prints. There may be a loop adjustment, but I think that I would concentrate on the registration rollers, and how the door fits to mate the two rollers. A flat spotted sep roller might make it worse also. =^..^=
  9. #9
    Technician bigdaddy's Avatar
    Join Date
    Feb 2015
    35
    Rep Power
    19
    Had this issue recently on another thread. Regional Tech came down today and it turns out the status page is skewed from the factory. If you use a test chart or make one you can tell if the image is actually skewing or not. Our's were not actually skewing. I know it sounds stupid but we tried on 8 different machines and all were the same, no skew to a half mm skew with test chart.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
