Results 1 to 3 of 3
  1. #1
    R0B
    Guest
    Question Utax 2500ci / Kyocera 2551ci – Toner exchangeable?
    As I understand the Utax 2500ci / Kyocera 2551ci is the same printer. I was wondering if parts are exchangeable and specifically if I can use the Kyocera 2551ci toner in the Utax 2500ci? Or do the chips differ?
  2. #2
    Field Supervisor 500+ Posts ntbann's Avatar
    Join Date
    Jan 2012
    Location
    Port Huron
    578
    Rep Power
    35
    Re: Utax 2500ci / Kyocera 2551ci – Toner exchangeable?
    It's called Destination. U265 > Copystar = 66, Kyocera Mita =2, Utax = 11, Olivetti = 12
    But keep in mind that your machine may no longer accept the original badge's toner. =^..^=
    With a quick search I found this post from Black Cat.
  3. #3
    teacher-guide-expert-guru 2,500+ Posts
    zoraldinho's Avatar
    Join Date
    Mar 2008
    Location
    SVN
    4,948
    Rep Power
    106
    Spare parts are identical. Most Toner containers have different guides.The chip is not the only barrier.
    Practice makes perfect
    If you want something done right, you have to do it yourself
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
