Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Join Date
    Mar 2010
    14
    Rep Power
    29
    Question Head Stumper Challenge
    I've got a 1" wide graduated shadow running the long edge of my copies that does not show on scans or prints of scans. It looks very physical, but how can it be???? If it was physical it would show on the scans also.
    It's a KM 1610FP. ;-]
    HELP!
    Chris
  2. #2
    Master Of The Obvious 10,000+ Posts
    blackcat4866's Avatar
    Join Date
    Jul 2007
    Location
    Lapeer, Michigan
    22,445
    Rep Power
    462
    Have you run a counter page or some other internal print, to determine if its optical or a print engine problem? =^..^=
  3. #3
    Join Date
    Mar 2010
    14
    Rep Power
    29
    line is not on any prints. machine reports or network prints. Only copies adf or glass, but not scans.
  4. #4
    Join Date
    Jul 2007
    Location
    Lapeer, Michigan
    22,445
    Rep Power
    462
    Quote Originally Posted by immortalvegan View Post
    line is ... only on copies from adf or glass, but not scans.
    Wow! I'm stumped! I can think of possibilities for ADF-not glass, or Glass-not ADF, but not affecting scans? I can't begin to explain that. Maybe an image processing issue... but scans should still be affected. =^..^=
  5. #5
    Join Date
    Mar 2010
    14
    Rep Power
    29
    My sentiments exactly.
  6. #6
    Field Supervisor 500+ Posts
    copytechman's Avatar
    Join Date
    Nov 2008
    Location
    Barrie, Ontario
    909
    Rep Power
    44
    Is it twain scan or push (where u can change settings @ the machine b4 sending), not familiar w/this model, but if you try to darken b4 scanning that'll typically make any irregularities show up on a scan too. Just a thought!
    Regards!
    A.
  7. #7
    FORMER Techie 1,000+ Posts tcs04's Avatar
    Join Date
    Apr 2009
    1,184
    Rep Power
    43
    HELP!
    Chris
    (RICOH TECH... But...) have you compared auto image density and manual image density modes?
    Some Ricoh machines scan a 1" (ish) band and apply the density to the whole main scan line when in auto ID mode, I have seen what sounds like similar problem caused by this. Not sure if a KM would have the same issue?
    May give you a clue as to the cause.
    Try copying an A3 (Large) sheet, reducing and rotating onto an A4 (small) sheet fed long edge first. Does the problem rotate and reduce? This would confirm the optics / scanner as the problem.
  8. #8
    Join Date
    Mar 2010
    14
    Rep Power
    29
    we'll never know now. I cleaned everything under the glass (again) to beyond pristine standards put 'er back together and wala... It's gone.
    Love the suggestions on rotate and reduce!!! Brilliant step!
    Thanks everyone, maybe this thread will save someone else some day.
  9. #9
    Join Date
    Apr 2009
    1,184
    Rep Power
    43
    WOOHOO!!
  10. #10
    Join Date
    Jul 2007
    Location
    Lapeer, Michigan
    22,445
    Rep Power
    462
    Congratulations. =^..^=
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
