Thanks Thanks:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    rockista_viii
    Guest
    TASKalfa 180/220 Problem blank copy
    please help me i replace a new toner in my copier but when i proceed in copying.the printout is blank or clear.please help me
  2. #2
    Join Date
    Feb 2010
    22
    Rep Power
    29
    Did you install OEM (original) toner? Also if you haven't already I would try a simple power reset along with opening the left side door and make sure it is all the way closed. If the side door is open there will be no transfer.
    Good luck
  3. #3
    rockista_viii
    Guest
    yes this is a original toner and i try it to reset it several times.nothing happen.please help
  4. #4
    Master Of The Obvious 10,000+ Posts
    blackcat4866's Avatar
    Join Date
    Jul 2007
    Location
    Lapeer, Michigan
    22,471
    Rep Power
    463
    rockista,
    It's unlikely that the changing of a toner cartridge had anything to do with blank copies.
    More likely, while you were in the machine you did something to the transfer charge roller or it's contacts. The way to confirm this is to emergency-stop the machine while the paper is passing the drum (open a door while the paper is passing the drum). If the latent image on the drum is properly developed, you can be certain that it is a transfer problem. The transfer roller may have been removed from the machine, and the rear contact spring may have fallen out. =^..^=
  5. #5
    rockista_viii
    Guest
    hmm any suggestion because I change only the empty toner.
  6. #6
    Join Date
    Jul 2007
    Location
    Lapeer, Michigan
    22,471
    Rep Power
    463
    Quote Originally Posted by blackcat4866 View Post
    rockista,
    ... The way to confirm this is to emergency-stop the machine while the paper is passing the drum (open a door while the paper is passing the drum). If the latent image on the drum is properly developed, you can be certain that it is a transfer problem. The transfer roller may have been removed from the machine, and the rear contact spring may have fallen out... =^..^=
    I think I just made a suggestion. =^..^=
  7. #7
    rockista_viii
    Guest
    ok thank you every one
    blackcat4866 thank you...
  8. #8
    Service Manager 5,000+ Posts
    Join Date
    Jan 2006
    Location
    Las Vegas, NV
    9,940
    Rep Power
    154
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
  9. #9
    Trusted Tech 50+ Posts
    Join Date
    May 2009
    92
    Rep Power
    31
    would imagine it most likely transfer or dev unit.
  10. #10
    tedy
    Guest
    Re: TASKalfa 180/220 Problem blank copy
    Hey there pls help me i have kyocera 220 photocopiar start to copy he gives blanck paper what is the problem?
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
