KM6030_8030 (UTAX CD1080 or Olivetti D800) Kam 50 Jam 46 Modification
Hello Everyone
I just wanted to share something with you my fellow tonermarshmellow fixers.
Came across a machine which was giving ocasional Jam 50 or Jam 46. I had new exit sensor, new eject rollers, new drive system.
After short investigation I put a bit of a developing thought to improve fallback of exit paper guide, that is run by a solenoid. It goes up quick, lacking to go down.(almost like with my exgirlfriend). Anyway this mod is inserted in the exit paper guide shaft located in the exit section of the fuser. This guide transfer the paper either out to finisher if copied from glass or down to duplex section if copied from document feeder. So the whole improvement is to make it fall fast back down and the most important thing is to keep it there, no middle rattle jumps.
Parts required:
1x paper clip
1x Separation spring which we used to take out from paper feed section.The silver one, which later was replaced with copper.
Bookmarks
