Results 1 to 5 of 5
Thread: Lexmark T642
    Field Supervisor 500+ Posts tcypy1961's Avatar
    Feb 2009
    Pensacola, FL
    696
    26
    Lexmark T642
    What would cause the transfer roller to cause faint prints in one printer but not when installed in another? I need to get a maintenance kit, as I know it comes with the fuser unit replacement parts, transfer roller, and charge roller, but I want to know that this is what I need to replace before I purchase one. Also, this is a repeat call to this customer and the transfer roller in the printer with the problem is its original roller, and it wasn't working on my first visit there. Thank you for any help given.
    Senior member of CRS 2,500+ Posts
    Lexmark T642
    ZOOTECH's Avatar
    Insane Diego, CA
    3,055
    85
    Re: Lexmark T642
    Quote Originally Posted by tcypy1961 View Post
    It might be a transfer high voltage problem; that could be why the roller works in one machine, but not the other.
    Field Supervisor 1,000+ Posts subaro's Avatar
    Oct 2010
    1,129
    31
    Re: Lexmark T642
    Also check the contacts where the roller sits and examine for crack or breakage. did you check the toner cartridge on the other machine too. most likely you did, but just checking in case you forgot.
    Check toner darkness settings. printout menu page or go to web admin and search there. If the settings are set low number then prints will be lighter.
    Lexmark T642
    16,286
    266
    Re: Lexmark T642
    So, can I assume that you have swapped transfer rollers with another device, and both devices seem to work? Charge loss issues are frequently a factor of environmental humidity. Back in the day, a slightly charred corona block might work for months, until a particularly rainy humid day, when the copies would go light. Charge loss issues are frequently very intermittent, and can come and go inexplicably.
    Were it me, I would install a new toner cartridge and transfer roller, and I would have reasonable confidence that I covered the two most likely causes. =^..^=
    Service Manager 1,000+ Posts theengel's Avatar
    Nov 2011
    North Bend
    1,563
    Re: Lexmark T642
    Sometimes your only recourse is the process of elimination. You can't really know until you do it.
    The maintenance kit comes with a whole new fuser, not fuser parts.
    Lexmarks tend to baffle me sometimes with their weird charging problems. I've had several machines (T642's) that I've had to give up on because they were too expensive to troubleshoot.
