Hi all
I attened a Lexmark C935 with 'Service Trabsfer Belt' message' with error '904.06' and found that the transfer belt cage in the printer (which the transfer belt slides into) was slightly warped.
The cage would not sit down properly at the front left side of the printer even with all PCU's and belt removed. Along with this, the locking bar which raises the belt up and down wasnt connecting with the cage lift mechanism properly and the black platic cover that covers the teeth on the left cage arm keeps popping off.
This eventually torn the belt!
Anyway, the customer decided to get a refurbished replacement machine which I tested and delivered and irt was working fine.
Now the customer has the exaxct same problem but the belt is not torn!!!! The belt cage/cradle does not sit correctly and the locking bar teeth are not connecting properly!
I searched online for this and know there is a tech bulletin on this but the only correspondance I found is where I have to log into Lexmark site which I do not have credentials for.
I wonder if this is being caused by the customer opening the locking bar too fast or not putting the PCU's in correctly????
My questions are as follows:
Has anyone encountered this before?
Can anyone supply the tech bulletin?
Im sure there is a Xerox version of this printer but unsure which one?
Many thanks all, looking forward to your reply!!
J
Bookmarks
