Results 1 to 8 of 8
Thread: SC544 Fuse
  1. #1
    Service Manager 5,000+ Posts
    SC544 Fuse
    copier tech's Avatar
    Join Date
    Jan 2014
    Location
    London
    7,560
    Rep Power
    182
    SC544 Fuse
    Hi chaps,
    Quick question, is the mpc3002 & mpc3003 fuse the same?
  2. #2
    Service Manager 1,000+ Posts
    SC544 Fuse
    Lagonda's Avatar
    Join Date
    Aug 2008
    Location
    Brisbane
    1,650
    Rep Power
    71
    Re: SC544 Fuse
    Quote Originally Posted by copier tech View Post
    Hi chaps,
    Fuse?? You mean the little glass tubes with the fine wire in side that vaporises if you get it wrong?? Or FUSER, the large mechanical bit that gets hot?
    Sorry, they are two distinctly different types of fuser, not interchangeable.
    p.s. the Ricoh, Savin and Lanier thread would be a better place to ask.
  3. #3
    SC544 Fuse
    Join Date
    Jan 2014
    Location
    London
    7,560
    Rep Power
    182
    Re: SC544 Fuse
    I was referring to the new unit detect fuse.
  4. #4
    SC544 Fuse
    Lagonda's Avatar
    Join Date
    Aug 2008
    Location
    Brisbane
    1,650
    Rep Power
    71
    Re: SC544 Fuse
    Ah thats better! A tad more information and it all becomes clear.
    Sorry, don't know if the genuine fuser detect fuses are interchangeable, I've never tried it, just used the fuse that comes in the H/R sleeve box. However when I've had to fool a copier into thinking that its had a new fuser I've manufactured my own using a 125mA fuse from a local hobby electronics supplier.
    I hope that helps.
  5. #5
    Retired 10,000+ Posts
    SC544 Fuse
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,242
    Rep Power
    992
    Re: SC544 Fuse
    Yes. Whenever we have to replace a sleeve unit due to PM count, I keep the fuse that comes with it for when I have to reset a fusing error code.
  6. #6
    SC544 Fuse
    Join Date
    Jan 2014
    Location
    London
    7,560
    Rep Power
    182
    Re: SC544 Fuse
    The reason I ask is we have a few 02's & 03's that keep throwing SC544, even though they have had new fuser sleeves replaced, thermopiles etc (I suspect a few of them are being pushed too hard)
    So i'd like to order a few spare fuses so the engineers can reset the error by replacing the fuse not the sleeve if it doesn't need it!
  7. #7
    SC544 Fuse
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,242
    Rep Power
    992
    Re: SC544 Fuse
    There was another thread that has some suggestions for other things to use instead of the fuse Ricoh provides.
  8. #8
    Join Date
    Mar 2013
    Location
    Meridian, MS
    1,152
    Rep Power
    50
    Re: SC544 Fuse
    ....just google PicoFuse 125ma....that should do it for ya!!!
    PS--I know on circuit boards they use 0 ohm resistors for smd fuseable links!
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
