Results 1 to 7 of 7
  1. #1
    Senior Tech 100+ Posts johnny32's Avatar
    Join Date
    Oct 2007
    Location
    cork
    100
    Rep Power
    35
    ricoh mp6002 sc 204
    Hi all
    Wondering if i could get some help with an sc204 on this model. Machine service manual stated its to do the laser unit. Following thw manual i have changed the laser driver board to no avail so followed it up by changung the polygon motor again to no avail and finally the harness between the two. This is where i have stalled and am looking for a solution urgently. Any hints tips greatly appriecated.
  2. #2
    Trusted Tech 50+ Posts
    Join Date
    Oct 2008
    Location
    Cape Coral, FL
    53
    Rep Power
    32
    Re: ricoh mp6002 sc 204
    A lot of these machines are running pretty dirty. Probable the laser sync detector is covered in toner (its right next to the toner recycle unit on the right side. You take off the right upper cover, a fan and bracket, and you should see a square sensor attached to the laser on the front side of the machine (upper left side looking from the side). Its a little tricky to get out, but cleaning it should resolve your code.
  3. #3
    Join Date
    Oct 2007
    Location
    cork
    100
    Rep Power
    35
    Quote Originally Posted by jfbar1 View Post
    Thanks for the info, so cleaned laser sync detector board with no joy. Found on line that it could be a false code for the drum ground so took it out and cleaned and also found a buid up on the drum shaft itself so cleaned and since then no issues so far.
  4. #4
    Join Date
    Jan 2017
    Location
    kuala lumpur,malaysia
    12
    Rep Power
    15
    i had this problem before....just clean contact pin behind drum unit.
  5. #5
    cornel
    Guest
    Angry Re: ricoh mp7502 sc 204
    Hi i have an mp7502 it give sc204 i have changed the polygon motor harnas and polygon board with no luck still gives the same code have cleaned the drum unit even tried a new drum unit still the same problem!! pls advise
  6. #6
    Just a tech 250+ Posts keithxxiii's Avatar
    Join Date
    Nov 2014
    464
    Rep Power
    28
    Quote Originally Posted by cornel View Post
    Check if you have a defective IPU
    Aye! Cut the crap
  7. #7
    Service Manager 10,000+ Posts
    ricoh mp6002 sc 204
    Phil B.'s Avatar
    Join Date
    Jul 2016
    Location
    Raleigh NC
    22,792
    Rep Power
    661
    re-read this thread... follow the suggestions...
    Next time PLEASE start a different thread since these are two different machines....
    did you search CTN for your issue or did you just piggyback on this thread?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
