I have 2 MP C300sr's I picked up for resale.
I updated both firmwares to the most recent that I have (2 years old ish).
Not sure if that matters, or if it would have worked beforehand, but one of them refuses to staple from ANY print driver. It works fine when I select stapling in copy mode, but when selecting it in the print driver it just ignores the command.
The other one works perfectly.
Are there Any TSB's or tips about what might cause this? I even tried some diffeent model drivers with the same result.
I have another machine that I could swap the finisher with to test (and likely will try over the weekend), but I feel like it's more likely a "system" problem
Thanks!!
Bookmarks
