Thanks Thanks:  0
Dislikes Dislikes:  0
Results 1 to 9 of 9
Thread: MP C2504 noise
  1. #1
    Senior Tech 100+ Posts
    MP C2504 noise
    Join Date
    Aug 2011
    170
    Rep Power
    30
    MP C2504 noise
    Brand new machine with vibration noise, suspect fuser. Can't find any bulletins on this, also looked at C2503 and found nothing. Customer not happy of course, any help appreciated. Thanks
  2. #2
    Service Manager 1,000+ Posts
    Join Date
    Jun 2012
    Location
    Turnhout
    1,662
    Rep Power
    49
    Re: MP C2504 noise
    Quote Originally Posted by Old Crow View Post
    Try "output check" via sp mode.
    By activating separated parts, it's easier to troubleshoot...
    Good luck
  3. #3
    Senior Tech 100+ Posts semi's Avatar
    Join Date
    Sep 2008
    Location
    UK
    187
    Rep Power
    34
    Re: MP C2504 noise
    Engine firmware?
    Version Modified Points or Symptom Corrected1.08:02 Symptom corrected:- An abnormal sound may occur after continuously printing 20 or morepages.- An abnormal sound may occur when the machine stops due to a wastetoner bottle full detection while printing 10 or more pages.- If a jam occurs while the fusing temperature is relatively high, forexample, while continuously running jobs, the fusing unit attempts toprevent its temperature from further increasing and may cause anabnormal sound or a wrap-around jam.- Color adjustment fails and the tone of the color may suddenly changewhile printing.- Machine may stall with an SC990, if the tray runs out of paper or a misfeedoccurs with the last page of the job.Other changes:- To enable quicker first print even under low temperature and lowhumidity environment, the default value of feed permit setting onC5504/MCP6004 was changed as follows:SP1-102-011[Temp:lowerelta:Press:Sp.1] 5->10
    Do not run fuser in output mode unless you remove the waste toner bottle 1st-you'll end up trashing the sleeve!
  4. #4
    Copier Combobulator 500+ Posts
    Join Date
    May 2016
    589
    Rep Power
    26
    Re: MP C2504 noise
    Quote Originally Posted by Mark Bbb View Post
    Good luck
    Keep in mind you can't run the fusing drive output with the fuser inside on the newer sleeve belt fuser machines.
    If you do you risk damaging or destroying the fusing sleeve.
  5. #5
    Ricoh Fanboy 1,000+ Posts Oze's Avatar
    Join Date
    Jul 2008
    Location
    Toowoomba,QLD
    1,662
    Rep Power
    64
    Re: MP C2504 noise
    I've had a faulty fusing pressure motor/exit motor do this from new.
    It's the combined motor...easy to get to.
    Ignore the bulletin attachment...it's for a different model....(didn't have my specs on)
    Attached Files Attached Files
  6. #6
    Retired 10,000+ Posts
    MP C2504 noise
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,242
    Rep Power
    992
    Re: MP C2504 noise
    I have gotten vibration noise from the bridge unit, eve when new.
  7. #7
    Join Date
    Jun 2012
    Location
    Turnhout
    1,662
    Rep Power
    49
    Re: MP C2504 noise
    Quote Originally Posted by sturmtrooper View Post
    Indeed, if you perform an "output check" via sp mode, activate the separate parts as short as possible!
    And open the paper trays, because it will feed the paper and you will get a jam..
    Etcetera, etcetera,...
  8. #8
    Field Supervisor 500+ Posts Zeldaman's Avatar
    Join Date
    Mar 2011
    Location
    Stuttgart/Baden Wuerttemberg
    942
    Rep Power
    47
    Re: MP C2504 noise
    Hi there!
    Had this last week, a MPC 5504 with 100k prints on it, the fuserīs groaning like a hungry bear. But itīs in the warranty, so we send it to RICOH. This is until now the only fuser with noise in the whole Metis-range.
    Greetings...
  9. #9
    MP C2504 noise
    Join Date
    Aug 2011
    170
    Rep Power
    30
    Re: MP C2504 noise
    Thanks for all the input. I was there for the same issue a few weeks ago and after running numerous copies it vibrated for about 10 seconds and then would not do it again. It was from the fuser area but can't swear to it actually being from the fuser. They do have a finisher so will keep bridge unit in mind also. Didn't know about damaging the fuser sleeve when running in test mode...thanks for that tip. Does it walk off and self destruct or from excess heat?? Had updated firmware even though new but will double check engine.
    Oze, was the faulty pressure/exit motor problem constant? Intermittent?
    The customer says it's doing a lot now so hopefully it will, while I am there. Can't go til next week though. Thanks again.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
