Thanks Thanks:  0
Dislikes Dislikes:  0
Results 1 to 5 of 5
Thread: MP7000 sc547
  1. #1
    Service Manager 1,000+ Posts digicor's Avatar
    Join Date
    Jul 2008
    Location
    tampa Florida
    1,127
    Rep Power
    45
    MP7000 sc547
    I have replaced the thrmisters, with the newer parts #s, this machine ran for 6 months no problems, 5000/10000 sheets per month
    all of a sudden i get the 547 out of the blue? I changed the thermisters again just now, its not going away, im thnking the PWS?
    I un plugged the machine for a little bit, still same code, even with the door open and the fuser pulled out?
    what can it be? and is it fixable with out sending the machine to the big dumpster in the recycle sky?
  2. #2
    Senior Tech 100+ Posts
    Join Date
    Jul 2010
    106
    Rep Power
    0
    Re: MP7000 sc547
    Did you reset SC code?
    Sent from my GT-I9195I using Tapatalk
  3. #3
    Retired 10,000+ Posts
    MP7000 sc547
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,242
    Rep Power
    992
    Re: MP7000 sc547
    SC 547 is a zero cross error. Either zero cross detection on the power supply or very trashy AC line voltage. If AC power is solar only, that could be the problem as solar may not be a true sine wave. Unless properly filtered, it is usually a stepped square wave which does not play nice with zero cross circuits as there is no actual zero cross.
  4. #4
    Ex-Tech Xcelsior's Avatar
    Join Date
    Jan 2017
    Location
    Millersburg
    24
    Rep Power
    15
    Re: MP7000 sc547
    Quote Originally Posted by slimslob View Post
    As Slime mentioned, check the power supply or power line.
    The other thing is to make sure the thermistor wires aren't pinched/damaged. If the metal bracket pinches one too tightly and gets through the sheath it can cause Zero-Cross errors.
    Makes sure the wires are in good shape then enter SP mode, door open, reset machine. If it won't clear, start checking the power for noise.
  5. #5
    Join Date
    Jul 2015
    178
    Rep Power
    21
    Re: MP7000 sc547
    Check the heat lamp connectors make sure the blue connector is connected to blue terminal and green is connected to green terminal.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
