Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Join Date
    Jun 2015
    Location
    UK
    5
    Rep Power
    0
    MPC4504 SC899 then SC991 then SC997
    Hi Guys
    Getting a strange fault
    Customer keeps getting SC899 but then it is followed by a SC991 and then a SC997.
    All the latest firmware has been stuck on including the latest cheetah panel and Java.
    Another strange thing is that although it sometimes happens in the afternoon it also happens at 1am , 4am , 9pm - Almost as if it is just sitting there and error codes.
    The machine also has safecom on
    Any suggestions?
  2. #2
    Senior Tech 100+ Posts
    Join Date
    Jun 2008
    Location
    Dorset
    176
    Rep Power
    0
    Re: MPC4504 SC899 then SC991 then SC997
    Are the Heap and Stack sizes correctly set? The values should be in the SDK (Safecom) manual. If not, set both to no more than 75% of the maximum value displayed on screen.
    User Tools, Machine Features, Extended Features, Extended Features, Admin Tools.
    Check/ set the diprint timeout to at leat 60 seconds. By default this is 15 seconds.
  3. #3
    Join Date
    Jun 2015
    Location
    UK
    5
    Rep Power
    0
    Thanks for replying Choro1dal
    Heaps and stacks are the same as the other 6 machines on site.
    I have changed the Diprint settings. Will see how it goes and let you know
  4. #4
    Professional Moron 2,500+ Posts TonerMunkeh's Avatar
    Join Date
    Apr 2008
    Location
    Shitsville, UK
    3,858
    Rep Power
    109
    But what are they set to?
    Hit it.
  5. #5
    How'd ya manage that? 1,000+ Posts
    Join Date
    Dec 2009
    Location
    NoneOfYoiurBusinessVille
    1,026
    Rep Power
    61
    I had a machine behaving similarly and ended up going through a reset procedure (from the TSRC in the US) for the Java platform. This applies to machines where Java is on flash memory and not an SD card.
    User Tools> System Settings> Admin Tools> Enhanced Authentication Management> OFF
    Stop all applications, including Java
    Disable Java in SP mode SP5-730-001 to 0
    Format HDD 'Data for design and printer fonts' SP5-832-009 (usually, verify in manual for your specific model)
    Perform SCS memory clear SP5-801-3
    Return all SPs from SP5-401-160 to SP5-401-230 to default setting
    Power Cycle
    Enable Java in SP mode SP5-730-001 to 1
    Power Cycle
    Install Java from SD card
    Reinstall applications.
  6. #6
    Join Date
    Jun 2015
    Location
    UK
    5
    Rep Power
    0
    Hi TonerMunkeh
    The Heap Size was - 32Mb and the stack size was 512KB
    Thanks Zed, i am going back to the customer on Monday to see if the machine has gone into an error state over the weekend, I was also thinking along the lines of something to do with Java, will give this a go and get back to you next week
  7. #7
    Join Date
    Apr 2008
    Location
    Shitsville, UK
    3,858
    Rep Power
    109
    Stack is set too high, I just had a 3503 with SC997 and setting the stack to 384 sorted it.
    Hit it.
  8. #8
    Join Date
    Aug 2017
    8
    Rep Power
    0
    Exclamation Re: MPC4504 SC899 then SC991 then SC997
    some thing new about this case?
    I have same problem on MPC4504SP with safecom.
  9. #9
    Hair Straightener Tech 500+ Posts rsyarcia's Avatar
    Join Date
    Feb 2008
    Location
    Nueva Vizcaya
    711
    Rep Power
    45
    with mp c2504exsp, we downgraded the java version. it was ok after...
    Nobody is perfect..
  10. #10
    Technician PJB's Avatar
    Join Date
    Apr 2015
    19
    Rep Power
    19
    All -04 Machines with Safe Com has to have Java 12.45 or lower to work. Anything higher will cause problem
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
