Results 1 to 7 of 7
  1. #1
    Join Date
    Aug 2017
    6
    Rep Power
    0
    Angry Ricoh MP C5503 - Scanner features are greyed out
    Having an issue with the C5503. Tested the machine at the office before delivery using scan to folder. It worked fine. Delivered machine to customer and now most of the scanner screen is greyed out (cannot select email or folder tabs). The Store File button is highlighed yellow. Clicking that it shows Store to HDD highlighted. The problem is that Store to HDD + Send is greyed out and I cannot highlight to scan to email.
    Any suggestions?
  2. #2
    Service Manager 5,000+ Posts
    copier tech's Avatar
    Join Date
    Jan 2014
    Location
    London
    7,561
    Rep Power
    182
    Re: Ricoh MP C5503 - Scanner features are greyed out
    Sounds like an issue with the HDD, maybe it has worked loose during transit, try removing & refitting.
    Also try a format in SP mode.
  3. #3
    Join Date
    Aug 2017
    6
    Rep Power
    0
    Quote Originally Posted by copier tech View Post
    I did format the HDD a(All) and it completed. Issue remains.
    Haven't tried reseatting the HDD cables. Will try that.
  4. #4
    Senior Tech 2,500+ Posts
    mikadonovan's Avatar
    Join Date
    May 2008
    Location
    Indianapolis, Indiana
    2,922
    Rep Power
    99
    Maybe check and make sure the sd card/cards have not popped out during transport.
    NEVER ASSUME ANYTHING
  5. #5
    Join Date
    Aug 2017
    6
    Rep Power
    0
    Will check into that. Thanks.
    When I bring up quick scan I eventually get "Connection with the machine has failed. Check the machine structure.". No amount of googling or TRSC brings up that message.
  6. #6
    Join Date
    Aug 2017
    6
    Rep Power
    0
    I know this is old, but the NIC was turned off. Thank you for the suggestions.
  7. #7
    Join Date
    Jan 2014
    Location
    London
    7,561
    Rep Power
    182
    Quote Originally Posted by smokeajayson View Post
    Interesting, it worked before you loaded in the van!?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
