Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 6 of 6
Thread: Ricoh MP7502
  1. #1
    Senior Tech 250+ Posts
    Join Date
    Jul 2009
    Location
    Den Bosch
    478
    Rep Power
    0
    Ricoh MP7502
    HI,
    got a problem with this machine regarding toner end message . .
    With a new toner bottle it says that the toner is almost empty (?)
    Despite the message the continues working and is also adding toner to the developer unit.
    The toner end melding does not come, only toner near end.
    Changed the bottle for another new one, no results. (message disappears for a while when changed the bottle)
    Checked the connectors and wiring.
    No much experience on this model . .
    Anyone?
    Thanks in advance
  2. #2
    Join Date
    Jul 2009
    Location
    Den Bosch
    478
    Rep Power
    0
    Re: Ricoh MP7502
    No one ?
  3. #3
    Join Date
    Sep 2015
    36
    Rep Power
    18
    Re: Ricoh MP7502
    Hello
    Ok heres a few things to check and change which could be at fault:
    1) Toner hopper motor. This could be faulty. Over time the motor starts losing its strength to rotate the toner bottle.
    Change toner hopper motor found in the hopper unit.
    This is your most likely fault.
    2) Check your toner flow sensor on your developer unit where your toner enters the unit.
    3) Developer could need replacement.
  4. #4
    Join Date
    Sep 2015
    36
    Rep Power
    18
    Re: Ricoh MP7502
    Also ! Please note that the toner hopper motor might rotate the bottle but the number of rotations that it can do will be far less then thats which is required. Therefore the machine will receive far less toner then it thinks it will.
    When testing the motor, it should be able to rotate the toner bottle very easily without any struggle.
  5. #5
    Retired 10,000+ Posts
    Ricoh MP7502
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,226
    Rep Power
    991
    Re: Ricoh MP7502
    My guess is that the toner end sensor on the side of the toner supply unit is flaky.
    From the 1060 service manual detailed description:
    The toner end sensor is checked every copy.
    • Toner near end. When the toner end sensor remains on for two consecutive pages, the toner supply motor turns on for 1.1 s. If the toner supply motor has turned on more than 30 times during the last 100 prints, the “Toner Near End” warning is issued. The warning is cleared if the toner end sensor turns off.
    • Toner end. If the toner end sensor remains on for about 1,000 copies (A4 size with 6% coverage), the "Toner End” warning is issued. If the toner end sensor switches off twice consecutively, the toner end sensor copy counter is reset to zero.
  6. #6
    Senior Tech 2,500+ Posts
    Ricoh MP7502
    mikadonovan's Avatar
    Join Date
    May 2008
    Location
    Indianapolis, Indiana
    2,921
    Rep Power
    99
    Re: Ricoh MP7502
    Quote Originally Posted by slimslob View Post
    I have had to replace more than one of these. Make sure the wiper is cleaning the surface of the sensor, too.
    NEVER ASSUME ANYTHING
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
