Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Service Manager 1,000+ Posts
    Aficio 2051 (b+w) with sc555 + sc552
    Join Date
    Aug 2007
    Location
    Brooklyn
    1,323
    Rep Power
    48
    Thumbs up Aficio 2051 (b+w) with sc555 + sc552
    Aficio w error sc555 + sc552. Cust had sc555 and knows
    Spmode reset. Did reset snd got sc552. Won't reset. Do i need
    thermistor or lamp as per SM.? Frank/AP
  2. #2
    Field Supervisor 500+ Posts
    Join Date
    Jun 2009
    Location
    /Florida
    552
    Rep Power
    39
    Re: Aficio 2051 (b+w) with sc555 + sc552
    if you have a spare fuser take that with you. If not then take thermistor, heater lamp, over temp sensor, upper fuser and lower pressure roller, bearings both upper and lower. Hope that will get you going. Could be a board problem too wont know till you get there and check it out.
  3. #3
    Join Date
    Aug 2007
    Location
    Brooklyn
    1,323
    Rep Power
    48
    Thumbs up Re: Aficio 2051 (b+w) with sc555 + sc552
    Thank you for your quick reply Copierman. Unfortunately i don't
    Have mich for that machine . Have thermistors + other parts
    not related to fuser. Frank
  4. #4
    Join Date
    Apr 2010
    Location
    the west
    662
    Rep Power
    38
    I would start with the thermistors and thermostats.
  5. #5
    Retired 10,000+ Posts
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,236
    Rep Power
    991
    Many times a fusing error code will change if you clear the code without repairing the problem. The same malfunction will result in a different code if it is detected at power up as opposed to during normal operation.
    The first that I used to do with these older machines was to check the thermostats with a meter. If one was open and I did not have a replacement with me, I would bypass until I could get back with a new thermostat. Replace with AW110066 Thermostat: 211°C. The older thermostats AW110052 and AW110040 had a reliability problem.
  6. #6
    Service Manager 1,000+ Posts Polarbear's Avatar
    Join Date
    Feb 2012
    Location
    Cape Town
    1,070
    Rep Power
    45
    Hi
    Seems like you are looking at a busted fusing lamp for both codes, or a lamp and end thermistor.
    SC 552:
    Heating roller warm-up error 2
    • The heating roller temperature does not reach the ready temperature for 65
    seconds after the fusing unit has rotated.
    The heating roller temperature does not reach 100°C for 25 seconds in the
    low temperature condition after the heating lamp on.
    • Dirty or defective thermistor (end)
    Heating roller fusing lamp broken
    Defected thermostat
    • Defective heating roller fusing lamp
    1. Check if the heating roller thermistor (end) is firmly connected.
    2.
    Replace the heating roller thermistor (end).
    3. Replace the heating roller fusing lamp.
    SC555:
    Heating roller lamp consecutive full power 2
    When the fusing unit is not running in the ready condition, the pressure roller-fusing
    lamp keeps ON full power for 130 seconds or more.
    • Broken heating roller thermostat
    Broken heating roller fusing lamp
    1. Replace the heating roller thermostat.
    2.
    Press the GREEN button!!
  7. #7
    Join Date
    Aug 2007
    Location
    Brooklyn
    1,323
    Rep Power
    48
    Thank you Copierman, Jonhiker ,Slimslob and Polarbear. So very grateful for your help. Turned out to be one of the thermostats. Frank
  8. #8
    Join Date
    Nov 2007
    Location
    New Jersey
    1,671
    Rep Power
    87
    Quote Originally Posted by axyun View Post
    Dirty thermistors usually cause that.
  9. #9
    Join Date
    Aug 2007
    Location
    Brooklyn
    1,323
    Rep Power
    48
    Got lucky. with thermos fuse. Easy enough to take care of. Thanks. frank
  10. #10
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,236
    Rep Power
    991
    Quote Originally Posted by anothertech View Post
    In my experience they are seldom the cause since they are normally replaced at each fusing unit PM. I have had to replace a lot more thermostats due to fusing errors.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
