0
0
Dislikes:
0
MPC5501 Photoconductor Unit Not Set Black
Had a tech swapping drums and DV units and we think he swapped wrong ones. Now machine says the Photoconductor is not set BLACK
Looking at them they all look the same. Any idea how to tell which DV unit and DRUM are for the MPC5501?
Sorry for the bonehead move here guys!
- Rep Power
- 38
Re: MPC5501 Photoconductor Unit Not Set Black
should be able to look at the dv unit to see what color it is. the message is usually associated with the connector on back side has been modified (when someone converts a k to a color drum). if the tech swapped wires on the k unit, trying to use it as a k unit, it will give that message.
No swapping of wires. Just had a bunch of dv units and drums that we swap around and now they are mixed up and physically looking at them tells us nothing. There is no number we can find on the actual unit. Any other ideas?
Message will also occur if the connector between the drum unit and the development unit is not fully plugged in.
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Bookmarks
