Results 1 to 7 of 7
  1. #1
    Join Date
    Oct 2017
    Location
    Johannesburg
    5
    Rep Power
    0
    Ricoh pro8120s paper jam
    Good day
    I have a ricoh pro8120s which is making paper jam when i print duplex, if i print simplex it prints fine, can someone help me
  2. #2
    Field Supervisor 500+ Posts
    totoro's Avatar
    Join Date
    Apr 2008
    569
    Rep Power
    41
    Re: Ricoh pro8120s paper jam
    Can you give us a jam code?
    Totoro
  3. #3
    Service Manager 10,000+ Posts
    Phil B.'s Avatar
    Join Date
    Jul 2016
    Location
    Raleigh NC
    22,790
    Rep Power
    661
    Quote Originally Posted by Hulisani View Post
    Good day
    where is it jamming? it should throw a code and on the screen tell you which section the jam is in. more info from you needed.
  4. #4
    Join Date
    Oct 2017
    Location
    Johannesburg
    5
    Rep Power
    0
    Quote Originally Posted by Phil B. View Post
    The jamming code is J030
  5. #5
    Join Date
    Oct 2017
    Location
    Johannesburg
    5
    Rep Power
    0
    Quote Originally Posted by totoro View Post
    Jam code is J030
  6. #6
    Retired 10,000+ Posts
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,242
    Rep Power
    992
    Service manual does not give much information on J030 other than Paper Late Jam. It does not say late where. A late jam usually means that the lead edge did not get to a sensor in time. Based on the sequence of jam numbers with J028 Being Registration Timing Main Trays, J029 Registration LCT, J031 Being PTR and the jam only occurring when doing duplex, my guess is that the lead edge edge late to the registration sensor when coming from the duplex unit.
    From Goose's Guide: Tech found drive belt for vertical transport (D1796764) for roller (D1796765) had ridden up unto edge of pulley causing timing error and J030.
  7. #7
    Join Date
    Oct 2017
    Location
    Johannesburg
    5
    Rep Power
    0
    Quote Originally Posted by slimslob View Post
    Ok thanks
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
