Results 1 to 7 of 7
  1. #1
    Trusted Tech 50+ Posts vga_man's Avatar
    Join Date
    May 2013
    Location
    Banha
    78
    Rep Power
    0
    Ricoh mpc2050 toner out
    Hello!
    After reinstall a new oem black toner cartridge... Copier made only 186 copy then toner cartridge became empty ☺
    Any ideas?
  2. #2
    Retired 10,000+ Posts
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,235
    Rep Power
    991
    Re: Ricoh mpc2050 toner out
    OEM is not the same as Genuine Ricoh. OEM merely means manufactured to Ricoh's toner menu, i.e. the same ratio of components. It does not mean to Ricoh quality or quantity.
    That said, take the cartridge out and shake it. Does the cartridge feel like it is empty? If not, you could have a bad RFID chip on the cartridge, a bad RFID board in the machine or a bad toner supply motor.
  3. #3
    Join Date
    May 2013
    Location
    Banha
    78
    Rep Power
    0
    Quote Originally Posted by slimslob View Post
    It's empty..
  4. #4
    Service Manager 1,000+ Posts fshead's Avatar
    Join Date
    Jan 2009
    Location
    nyc
    2,348
    Rep Power
    80
    Quote Originally Posted by vga_man View Post
    It's empty..
    i always ck aftermarkets to see how much toner is really inside b4 trying them...
    even use a scale to compare
  5. #5
    Copier Combobulator 500+ Posts
    Join Date
    May 2016
    589
    Rep Power
    26
    It's empty..
    Sounds like you got taken for a ride then.
  6. #6
    Senior Tech 2,500+ Posts
    mikadonovan's Avatar
    Join Date
    May 2008
    Location
    Indianapolis, Indiana
    2,922
    Rep Power
    99
    I suppose it's possible to do that at heavy density and close to 100% fill.
    NEVER ASSUME ANYTHING
  7. #7
    Join Date
    Jan 2009
    Location
    nyc
    2,348
    Rep Power
    80
    i have seen some non oems out there that look like starter toners,meaning like 1/5th of what you get in OEM..
    If you have a real issue your waste bottle will fill up fast.....and you will know as that toner needs to go somewhere
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
