Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    Join Date
    Sep 2015
    Location
    London
    15
    Rep Power
    18
    Ricoh MP 3045 toner light
    Hi all!
    Have a Ricoh MP3045 with a toner light that won't go out. After the toner was replaced we replaced developer and the toner tray mechanism. The machine is able to add toner in service mode (force toner) but then the light will come on in 20-30 copies. I also increased the toner supply rate but no luck.
    Thanks!
  2. #2
    Senior Tech 100+ Posts
    eccelobo's Avatar
    Join Date
    May 2013
    Location
    Buenos Aires
    113
    Rep Power
    25
    Re: Ricoh MP 3045 toner light
    How many copies have the drum and developer? The tóner is OEM?
    Enviado desde mi SM-G920V mediante Tapatalk
  3. #3
    Join Date
    Sep 2015
    Location
    London
    15
    Rep Power
    18
    Quote Originally Posted by eccelobo View Post
    The developer is new and the drum has less than 20k
  4. #4
    Professional Moron 2,500+ Posts TonerMunkeh's Avatar
    Join Date
    Apr 2008
    Location
    Shitsville, UK
    3,856
    Rep Power
    108
    If you cheat the front door and look into the toner hopper, can you see the bottle turning when it's trying to add toner? Which developer did you use?
    Hit it.
  5. #5
    Service Manager 1,000+ Posts
    FrohnB's Avatar
    Join Date
    Jul 2017
    Location
    Nebraska, USA ------ GO BIG RED
    1,919
    Rep Power
    126
    Agree with tonermunkeh, have had many toner bottle motors go out on this series. That's one thing to check. Otherwise, check to see if there's a plug left in the toner hopper, or the plug to block toner chute on PCU unit when you flip it over. Did you initialize the new developer with 2-801 when you changed it? Possible bad TD sensor in Development unit, swap with a different/new one if available and see if it holds toner concentration.
  6. #6
    Join Date
    Sep 2015
    Location
    London
    15
    Rep Power
    18
    Quote Originally Posted by TonerMunkeh View Post
    Thanks! Yes I used the proper Ricoh developer. I can hear the machine trying to add toner but I did'n take a visual. I will try this next.
  7. #7
    Join Date
    Sep 2015
    Location
    London
    15
    Rep Power
    18
    Quote Originally Posted by FrohnB View Post
    Thanks! I did check for a plug. I did initialize the dev too. Would the dev initialize with a bad TD sensor?
    Thanks again!
  8. #8
    Senior Tech 250+ Posts fbkhan3's Avatar
    Join Date
    May 2012
    415
    Rep Power
    30
    if you can see the toner bottle rotating when force toner is executed, then dismantle the toner Hopper ,carefully look for 4 Mylars inside, these actually tend to flip or drop with wear and tear. you can either glue them back or change the hopper . this has been the case with 2035,2045,DSM 35/45 series.
    Edit: if toner Tray mechanism means toner Hopper unit replaced then kindly ignore the post.
    Regard's
  9. #9
    Retired 10,000+ Posts
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,236
    Rep Power
    991
    Are you sure you have the correct toner bottle? Some older models used a different bottle. Same diameter, same length, the only difference was the bottom of the bottle where the toner motor drives the bottle.
    With the previous model number, the 2045, there were two different version. The 2045 and the 2045e used different bottles. Symptom of the wrong bottle was exactly what you are getting.
  10. #10
    Join Date
    Sep 2015
    Location
    London
    15
    Rep Power
    18
    Quote Originally Posted by fbkhan3 View Post
    Regard's
    Thanks! Yes the hopper is new!
    Thanks!
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
