Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 6 of 6
  1. #1
    Join Date
    Apr 2009
    Location
    Columbus,NE
    18
    Rep Power
    31
    Savin C2525 and SC555
    I got a real problem machine with this C2525. It keeps popping a SC555 code about every week. I can reset it and its fine until it decides that it needs some attention. I've replaced the whole Fuser and Power supply but it keeps coming back. I'm now asking for help with it, so if you have any other ideas I'm open to them.
  2. #2
    Professional Moron 2,500+ Posts TonerMunkeh's Avatar
    Join Date
    Apr 2008
    Location
    Shitsville, UK
    3,855
    Rep Power
    108
    Next step would be thermopile and BICU board I think.
    Hit it.
  3. #3
    Passing Duplication Xpert 1,000+ Posts cobiray's Avatar
    Join Date
    Mar 2008
    Location
    York, PA
    1,200
    Rep Power
    45
    You might want to check your source power also. Does it happen at the same time of day or when something else turns on (fridge, air con, etc).
  4. #4
    Join Date
    Apr 2009
    Location
    Columbus,NE
    18
    Rep Power
    31
    I thought about it being a voltage issue, but I'm not sure about it being that. Took me about 6 tries before they would put a surge protector on it, since its not under a service agreement. If and when they call back I'll take a bicu board and thermopile.
  5. #5
    Join Date
    Mar 2008
    Location
    York, PA
    1,200
    Rep Power
    45
    Maybe move it to a different room just to give it a whirl. Seems they would be up for something free for a fix if they don't have a maintenance agreement.
  6. #6
    Join Date
    Dec 2009
    21
    Rep Power
    30
    Quote Originally Posted by halac0ax View Post
    I had the same problem on Friday with an MP 9001. There is a TSB that might apply. rfg040429,
    SYMPTOM:
    A SC542 or SC555 occurs.
    CAUSES:
    Temperature misdetection has occurred by the thermistors.
    When using paper with a high paper dust content, the amount of toner that sticks to the surface of
    the fusing roller increases. This toner and paper dust mix then sticks to the temperature-detecting
    elements of the thermistors. As a result, the thermistors are unable to detect the temperature of the
    fusing roller correctly.
    SOLUTIONS:
    If the symptoms occur:
    1. Clean or replace the Fusing Roller.
    NOTE:
    If the fusing roller is dirty, the toner and paper dust tends to stick to the thermistor more easily.
    If the SC codes continue:
    2. Replace the Middle and Rear Thermistor Brackets.
    NOTE:
    This will secure the thermistors in the correct position, which ensures that they can detect the
    roller temperature correctly.
    The distances [A] are different between
    the new and old style brackets.
    Old P/Ns - B1404196/7: 14.8 mm
    New P/Ns - D0624196/7: 15.3 mm
    PART NUMBERS ARE FOR THE MP 9001.
    From the c2525 service manual.
    SM 4-51 B230/B237
    Trouble
    shooting
    No. Type Details (Symptom, Possible Cause, Troubleshooting Procedures)
    Pressure roller lamp consecutive full power 2
    When the fusing unit is not running in the ready condition, the pressure
    roller-fusing lamp keeps ON full power for 8 seconds or more.
    Broken pressure roller fusing lamp
    Related SC code: SC 545
    555 A
    1. Replace the pressure roller fusing lamp.
    2. Replace the PSU.
    AND
    Heating roller fusing lamp consecutive full power 1
    When the fusing unit is not running in the ready condition, the heating
    roller fusing lamp keeps on full power for 8 seconds.
    Broken heating roller thermistor
    Related SC code: SC 555
    545 A
    1. Replace the heating roller thermistor.
    Seems very similar to what I had by your description.
    Let us know if it works or if you need more help.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
