Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 3 of 3
  1. #1
    Technician bunnthebody's Avatar
    Join Date
    Oct 2008
    Location
    friendship, TN
    38
    Rep Power
    32
    bypass tray locked
    I am working on an mpc3001. The bypass tray works when copying. It shows a lock symbol on the printer screen. We have deleted and reinstalled the machine with two different postscript drivers. We have changed
    every setting that we can think of on the machine and the computer. I moved the 11x17 paper to tray 2 and the job prints fine. When we print to the bypass, it prints out of tray 1 that has 8.5x11. Any help would be appreciated.
  2. #2
    Senior Tech 100+ Posts
    Join Date
    Jun 2008
    Location
    Dorset
    176
    Rep Power
    0
    Re: bypass tray locked
    The key/lock symbol displayed on the MFD's operations panel alongside a paper feed tray and/or bypass is an indicator. It identifies whether Auto Paper Select is enabled (No Key/Lock) or disabled (Key/Lock) per station.
    The Auto Paper Select function is not supported for the bypass tray, hence the lock symbol is permanently displayed.
    Auto size detect is supported for standard paper sizes (RT* (Printer Operators) Manual) all other sizes and types need to be configured in User Tools. Provided the configuration in User Tools, page set up in the application and the print driver match the job will be printed from the correct station.
  3. #3
    Service Manager 2,500+ Posts
    bypass tray locked
    sandmanmac's Avatar
    Join Date
    Feb 2009
    Location
    Toronto, ON
    3,885
    Rep Power
    159
    If you want to print to the bypass tray, it has to be manually selected from the printer properties
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
