Hi all. Decided to join this forum since I am doing more and more copier repair these days. In my area there are a ton of Ricohs around so I've done a lot of work on many of them. However I have a puzzling one that I don't quite know what to think of.
This Aficio 3228c is giving an SC541 error code. Looked it up and it said it was a thermistor problem in the fuser. Okay. Ordered the 2 thermistors. Replaced them yesterday. Error code is still there on startup. I've read MANY posts online about how to clear this code.....the main one being about hitting the clear modes key, then 107, then hold down the red button til SP mode comes up. Then shut the power off. This is supposed to clear the code. It didn't. I also found another post somewhere about actually going IN to one of the SP groups.....and look for page 5810. The 3228c has that. It says "Clear SC codes" and then has an "Execute" button. Again....thought I had it. Nope. Same problem.
I also noticed that the fuser was not getting hot warm at all. If the heating element in the fuser has died, could that be the problem? Would this produce the SC541 error code? It would make sense that the copier thinks the thermistor is bad because it can't sense any heat. But then again, there won't be any heat if the fuser isn't heating up. I would certainly think if the fuser heater isn't working that should throw a different code, not a thermistor code....but then again I could be wrong. I also can't help but wonder if there is still just some simple procedure I don't know about to try to clear that code and maybe that's why it's still not working.
What do you guys think??
Michael n wyo
Bookmarks
