Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Service Manager 250+ Posts
    Join Date
    Mar 2007
    Location
    Ontario
    277
    Rep Power
    0
    Ricoh MPC 3500 cant login
    OK guys when I enter user tool counter and then press the log in button it just beeps and wont let me . Is there a 5 mode memory clear function to erase this . If so what is it called ?
  2. #2
    Service Manager 1,000+ Posts
    teebee1234's Avatar
    Join Date
    Jul 2008
    Location
    Atlanta, GA
    1,671
    Rep Power
    59
    Re: Ricoh MPC 3500 cant login
    Does this device the fax option and if so, when you select the fax function hard key does it say 'loading'? I had this issue before and I had to disconnect the fax board from the controller in able to access user tools. Once I reseated everything, it all went back to normal. Not sure if this is your issue, but worth a try.
  3. #3
    Join Date
    Mar 2007
    Location
    Ontario
    277
    Rep Power
    0
    Everything loads OK the fax works the scanning to email works its just the printer doesnt and I cant log in once user tools and counter is depressed .
  4. #4
    teebee1234's Avatar
    Join Date
    Jul 2008
    Location
    Atlanta, GA
    1,671
    Rep Power
    59
    Does the printer function load when you select the Printer key? If not, reseat the Printer sd card along with the controller board. Next step would probably be to memory clear the Printer application settings (not all) - SP5801-008.
  5. #5
    FORMER Techie 1,000+ Posts tcs04's Avatar
    Join Date
    Apr 2009
    1,184
    Rep Power
    43
    login as admin and retry
  6. #6
    Field Supervisor 500+ Posts Bantams's Avatar
    Join Date
    Jun 2012
    Location
    Bradford, West Yorkshire
    603
    Rep Power
    37
    The Manual for this machine can be found Documents
  7. #7
    Service Manager 1,000+ Posts Llama God's Avatar
    Join Date
    Mar 2009
    Location
    Newcastle upon Tyne
    1,355
    Rep Power
    47
    2 posts for the same fault?
    http://www.copytechnet.com/forums/ri...interface.html
    Firstly, do you need administrator authentication turned on?
    Secondly, what are the username and password that you're using?
    Thirdly, can you log into the machine using the super special secret login and change the admin username and password?
    Forthly, have you RTFM?
    There, I'm all out of questions.
  8. #8
    Join Date
    Mar 2009
    Location
    Newcastle upon Tyne
    1,355
    Rep Power
    47
    Sorry, I take back part of my previous comment.
    3 posts for the same fault? Are you taking the piss now?
    http://www.copytechnet.com/forums/ri...upervisor.html
    http://www.copytechnet.com/forums/ri...ant-login.html
    Do you think that we all have nothing better to do than to read manuals for you?
    Sorry, harsh but fair criticism I think you'll find.
  9. #9
    ricoh5006
    Guest
    Quote Originally Posted by Rick View Post
    Login to WIM to clear all authentication.
  10. #10
    Join Date
    Mar 2007
    Location
    Ontario
    277
    Rep Power
    0
    Sorry but you were all wrong I do have the manual and have read this til 2:00 am and found the problem in the nvram. Thanks for your critc
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
