Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Trusted Tech 50+ Posts
    Join Date
    Oct 2008
    Location
    Italy
    79
    Rep Power
    32
    SC400 on mpc2051
    Hello guys,
    I have a mpc2051 that sometime indicates SC400.
    The machine has a total of 110k, 10k colors referred to.
    On this machine the problem has happened several times, and each time I have found that the shutter of itb which is located above the sensors id, in the inner part is dirty with toner.
    The toner is 90% black, there are only very small machines of cyan and magenta (even if in reality they are almost invisible).
    Cleaning the shutter and the edges of the holes of the same, through which, the sensor id make their reading, the problem is solved at the moment.
    Based on what the machine is working, however, and after a couple of months the problem returns.
    In late July, I replaced the ITB cleaning unit.
    Yesterday, after two months, the problem has come back, and as a precaution I replaced the black pcu, even if there are no quality problems.
    I tried to lightly beat the development unit but there has been no loss of toner.
    I took a look inside the machine and I have not encountered any loss of toner.
    Possible that the ITB cleaning unit is defective?
    Do you have any idea for me?
    Thanks in advance.
  2. #2
    Professional Moron 2,500+ Posts TonerMunkeh's Avatar
    Join Date
    Apr 2008
    Location
    Shitsville, UK
    3,858
    Rep Power
    109
    Re: SC400 on mpc2051
    On 110k the ITB cleaning unit needs replacing anyway. The Diana has always suffered from SC400, it's just one of those things these machines do. There's also a lot of threads regarding this:
    http://www.copytechnet.com/forums/se...earchid=193989
    Hit it.
  3. #3
    Join Date
    Oct 2008
    Location
    Italy
    79
    Rep Power
    32
    Quote Originally Posted by TonerMunkeh View Post
    In fact, the ITB cleaning unit I replaced it about 2 months ago.
    I'll try to click on the link that I have posted.
    Thank you.
  4. #4
    former propeller tester 250+ Posts
    Join Date
    Dec 2009
    478
    Rep Power
    34
    does anyone know if 'that guide plate' is earthed. if not maybe it needs to be, or some sort of mod. maybe remove it
  5. #5
    Trusted Tech 50+ Posts withnail's Avatar
    Join Date
    Apr 2010
    Location
    Wellington NZ
    59
    Rep Power
    29
    Check the mylar on the ITB cleaning unit blade isn't deformed, I've had to replace the unit early before due to this
  6. #6
    Join Date
    Oct 2008
    Location
    Italy
    79
    Rep Power
    32
    Quote Originally Posted by withnail View Post
    At the next visit I check the Mylar.
    But, ironically, it should also cause poor print quality?
    I have the mpc2050 with 150k and more and the ITB cleaning unit I've never replaced as well as black pcu and I've never had the SC400.
    During the surgery I took out all the group itb pcdu and all, but only the shutter was dirty.
    Maybe BLAD is right when he says it could be the shutter to attract the toner for reasons grounded.
    What do you think?
  7. #7
    ddickens
    Guest
    When I encountered this problem, I did what you did, but I had to replace the ID sensor and ITB unit to get the problem to go away.
    Hope this helps...
  8. #8
    Service Manager 5,000+ Posts
    SC400 on mpc2051
    Join Date
    Jan 2006
    Location
    Las Vegas, NV
    9,940
    Rep Power
    154
    Lightbulb Re: SC400 on mpc2051
    Paul@justmanuals.com
  9. #9
    Join Date
    Oct 2008
    Location
    Italy
    79
    Rep Power
    32
    Quote Originally Posted by ddickens View Post
    Hope this helps...
    But the entire itb unit or only the itb cleaning unit?
  10. #10
    Ricoh Fanboy 1,000+ Posts Oze's Avatar
    Join Date
    Jul 2008
    Location
    Toowoomba,QLD
    1,662
    Rep Power
    64
    When I've had it...it was replace the I.D sensor unit only....but with a huge cleanup as well.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
