Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. #1
    Senior Tech 100+ Posts
    Join Date
    Aug 2009
    178
    Rep Power
    31
    MPC4503 and 5503 paper curling
    Hey guys, Im seeing paper curling a lot on the new 03 range. So far the fix is to put on the modified paper exit trays so it stacks nicer - but it dosnt stop the paper curling.
    Before anyone says its damp paper...its not. Fresh reams do it too, turned both ways around! Ive also played around with fuser temps with no fix, and updated firmware.
    Its gotta be happening everywhere, anyone got any fixes?
    Cheers.
  2. #2
    Retired 10,000+ Posts
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,228
    Rep Power
    991
    Re: MPC4503 and 5503 paper curling
    Your profile does not show where you are from so we cannot know what the temperature and humidity is like there. It takes only a couple of hours for paper to pickup moisture. Usually shows as the first 8 to 10 sheets out of the paper tray in the morning coming out curled. I have had customers where the curl was enough that the paper rolled it self into about inch and a halt diameter tubes. Even "fresh reams" that have been stored where they are exposed to cold and/or humidity can absorb moisture, unless the wrapper provides a full moisture barrier. Try turning on the Anti-condensation heater SP5805.
  3. #3
    Field Supervisor 1,000+ Posts Eric1968's Avatar
    Join Date
    Jan 2009
    Location
    Rotterdam, Netherlands
    2,460
    Rep Power
    72
    Ricoh provides a tool to measure the amount of moisture in a ream of paper (unfortunately I don't know the part number..). It should be between 35-45%. I've measured 55% and higer in "fresh reams" of paper.
  4. #4
    The New Guy 1,000+ Posts ruben's Avatar
    Join Date
    Oct 2012
    Location
    Bristol, UK
    1,204
    Rep Power
    56
    It isn't damp paper for these, it is a terrible paper exit path. They have additional small rollers to counter this but they are ineffective. It happens less with a bridge unit, but that could be an expensive solution.
  5. #5
    Join Date
    Sep 2012
    Location
    Bristol
    16
    Rep Power
    24
    we are seeing the same problem , and also on the new black and white 03 range as well , we have tried all sorts of fix's , "tweaking" the input guide on the finisher sometimes helps but not always .
  6. #6
    Service Manager 250+ Posts turbojetboy's Avatar
    Join Date
    Aug 2009
    Location
    Adelaide
    279
    Rep Power
    34
    Have a look at this bulletin, regarding feeder issues. Note the settings and talk re paper curl.
    Attached Images Attached Images
  7. #7
    Join Date
    Aug 2009
    178
    Rep Power
    31
    Quote Originally Posted by turbojetboy View Post
    We must get different bulletins from you guys...havnt seen that one. Im gonna give those SP's a go, cant hurt. Will update with the results!
    Thanks!
  8. #8
    Join Date
    May 2011
    212
    Rep Power
    29
    Good morning everyone.
    I have been having the same problems. And now that winter is here, major problems will arise. I have hundreds of equipment Metis series.
    The suggestion to activate the SP 5805 applies only in the case of equipment that have the "Anti-Condensation Heater". If you do not have this option enable this SP is useless.
    The equipment installed in the south of Europe "Anti-Condensation Heater" is optional.
    I agree that this is one of the solutions to the problem, however a change in the output paper tray decreasing the drop of the paper will be less expensive
  9. #9
    Field Supervisor 500+ Posts Zeldaman's Avatar
    Join Date
    Mar 2011
    Location
    Stuttgart/Baden Wuerttemberg
    942
    Rep Power
    47
    Hi there!
    Since 2 or 3 month, all new delivered METIS are equiped with a new "springbased" paperexit-plate.
    If the paper is not to "crapy" itīseems to me, that the problem is solved.
    Greetings...
  10. #10
    Dirty toner monkey 50+ Posts
    Join Date
    Feb 2014
    Location
    Cambs
    55
    Rep Power
    21
    I had a similar problem on a MPC 4503. Paper was curling and jamming all the time, I spoke to Ricoh technical and they said its to do with the "Green" fuser technology. However. I have updated the firmware in a number of these machines with Firmware dating from around July this year, and it has pretty much stopped any curling issues.
    Depending on when you updated the firmware, I would emphasise the need to make sure ALL firmware is updated to the latest firmware possible, see if this helps.
    Alex
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
