Results 1 to 4 of 4
  1. #1
    Senior Tech 250+ Posts
    Join Date
    Sep 2013
    Location
    Burleson
    495
    Rep Power
    27
    MP C4502 Hardrive size
    What is the Hardrive size for an MP C4502? And also how do you get into the sc mode on it?
  2. #2
    Retired 10,000+ Posts
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,210
    Rep Power
    991
    Re: MP C4502 Hardrive size
    Quote Originally Posted by ABS tect View Post
    Look on the label on the existing HDD
    Create an error on the machine. Or did you mean SP mode. If you meant SP mode, you should not be working on Ricoh equipment as it is common knowledge for all Ricoh qualified technicians.
  3. #3
    ikerl
    Guest
    [Quote = slimslob; 462163] Mira en la etiqueta en el disco duro existente Crear un error en la máquina. ¿O te refieres modo SP. Si te referías modo SP, no debe estar trabajando en equipos Ricoh, ya que es de conocimiento común para todos los técnicos calificados Ricoh. [/ Quote]
    +1
  4. #4
    It's not easy being green 1,000+ Posts Cipher's Avatar
    Join Date
    May 2006
    1,309
    Rep Power
    57
    Originally the 4502 came with an 250Gb 2.5" SATA HDD but the official replacement part is now an 320Gb HDD.
    As long as the controller can detect the HDD, it should work.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
