Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Senior Tech 250+ Posts
    Join Date
    Feb 2014
    Location
    Bristol
    457
    Rep Power
    26
    Sharp MX2614 - C4-00 Error
    Ok, called out to a MX2614 today with a C4-00 code, replaced the PTC Unit and then it got interesting!!
    Machine works ok when using mono but when you try to copy or print in colour the C4-00 code comes back.
    Cleaned ID sensors, Drums etc but the fault remains.
    Anyone come across this?
  2. #2
    Join Date
    Nov 2016
    Location
    Bremen
    258
    Rep Power
    21
    Re: Sharp MX2614 - C4-00 Error
    Hi
    please control this CCE1479.pdf
  3. #3
    Join Date
    Feb 2014
    Location
    Bristol
    457
    Rep Power
    26
    Quote Originally Posted by OlliK1969 View Post
    Hi
  4. #4
    Field Supervisor 500+ Posts
    Join Date
    Dec 2009
    Location
    Waukegan IL
    961
    Rep Power
    58
    I had this problem before. You need to replace the transfer switching clutches in the back of the machine. If you take off the toner waste bottle and run a black copy and watch the black cam on front of the transfer unit and then run a color you will see that cam move as the clutch slipps and then you get the code. you have to remove the whole drive assy that goes across the back of the machine to replace the clutches. Its not very hard to get off.
  5. #5
    Join Date
    Dec 2009
    Location
    Waukegan IL
    961
    Rep Power
    58
    Ok,I see what I posted about the clutches is the same as the bulliten from the post before from olik1969. I have found this to be almost as common as the board causing the problem.
  6. #6
    Join Date
    May 2010
    Location
    Dallas, TX
    310
    Rep Power
    38
    Replace the transfer control PWB . We had a 2610 do the same thing. Replaced the primary and secondary belt units and both main power boards, the ptc and did a full pm and still were dead. Replaced the transfer control pwb and now works like a champ. RDENU0133FCPZ TC PWB
  7. #7
    Technician Sharpshooter's Avatar
    Join Date
    Jan 2009
    21
    Rep Power
    31
    Check that Transfer PWB has not been fitted correctly.
    See the attached file.
    C4_00.pdf
  8. #8
    Join Date
    Feb 2014
    Location
    Bristol
    457
    Rep Power
    26
    Changed black & colour transfer belt clutches and it's sorted.
  9. #9
    Trusted Tech 50+ Posts
    Join Date
    Jul 2008
    97
    Rep Power
    33
    I also had problem C4-00
    A malfunction of the high-voltage unit is detected.
    Out of order: transistor, diode and fuse.
    The photo is attached.
    Attached Images Attached Images
  10. #10
    The New Guy 1,000+ Posts ruben's Avatar
    Join Date
    Oct 2012
    Location
    Bristol, UK
    1,204
    Rep Power
    56
    Quote Originally Posted by vlad_ View Post
    This part has since been modified to prevent this, new P/N is RDENU0154FCP2.
    See: MX2614N-MX3114N256.pdf
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
