Results 1 to 4 of 4
  1. #1
    Senior Tech 250+ Posts
    MX-4070 with MX-FN28 Stapling issue
    Join Date
    Oct 2008
    Location
    Manchester, NH
    459
    Rep Power
    37
    When compiling the paper in the compiler, not all sheets are brought back in. When it goes to staple 1 or 2 sheets will be out 1 to 1.5 inches and miss the staple.
    Replaced the roller, shaft and gear that brings the paper back in to the compiler. The shaft and gear are both updated parts.
    Any help is appreciated.
  2. #2
    Join Date
    Oct 2008
    Location
    Manchester, NH
    459
    Rep Power
    37
    Re: MX-4070 with MX-FN28 Stapling issue
    You may be able to disregard. Appears to have something to do with static. Rubbed a fabric softener sheet and has not screwed up in 14 sets. Could not get past one set without screwing up befor.
  3. #3
    Join Date
    May 2010
    Location
    Dallas, TX
    310
    Rep Power
    38
    I have seen this issue and have done the fabric softener sheet thing too. Wanted to point out that there are SEVERAL firmware updates for these, some major having to do with machine timing. May want to look at doing those if you havent already. If you do, make sure and update the OCR firmware before the machine firmware or you may end up with a dead machine.
  4. #4
    Join Date
    Jun 2016
    458
    Rep Power
    24
    I have an MX-5071 with FN28 with the same problem.
    First page isnt pulled back enough and doesnt get stapled.
    FW is latest.
    Just ordered the Gathering roller hoping this will solve it.
    0JED3B92621A/ gathering roller
    Other suggestions are welcome
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
