Thanks Thanks:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Join Date
    Oct 2017
    Location
    Knoxville
    12
    Rep Power
    14
    Sharp MX-950M Job Stuck
    So this is a new one for me, I have a job that continually prints out of the printer. I can't find it in in any printer queue on our network. But every time I restart the printer this same job tries to print. Is there a way that I can clear out the printer's queue somehow?
    Thanks,
    KipCody
  2. #2
    Field Supervisor 500+ Posts
    mansart's Avatar
    Join Date
    Apr 2009
    846
    Rep Power
    54
    Re: Sharp MX-950M Job Stuck
    sim 66-10 will clear print queue on machine......but if in someones print queue it will be back.
    Is machine shared off server? if so look at print queue on server and clear it
  3. #3
    Senior Tech 250+ Posts driving lots of miles's Avatar
    Join Date
    Jun 2016
    Location
    Kansas
    364
    Rep Power
    22
    If you turn off the machine and unplug the network cable and then restart the machine and it does not try to print then it is in someone's print que. When you then plug the network cable in again and it tries to print it is definitely in someone's computer.
  4. #4
    Join Date
    Oct 2017
    Location
    Knoxville
    12
    Rep Power
    14
    So I ran Sim 66-10 and restarted without the network plug installed. Plugged in the network cable and everything seemed fine at first. Then the job came back again. The printer is not installed on our server, but looks like I'll be going to all workstations to make sure I don't have a file hung up somewhere. I'll let you all know what I find out.
    Thanks,
    KipCody
  5. #5
    Service Manager 1,000+ Posts igi's Avatar
    Join Date
    Apr 2009
    Location
    ATLANTIS
    1,507
    Rep Power
    51
    Hi
    latest firmware + latest driver=start from there.
    good luck.
  6. #6
    Master Of The Obvious 10,000+ Posts
    blackcat4866's Avatar
    Join Date
    Jul 2007
    Location
    Lapeer, Michigan
    22,471
    Rep Power
    463
    It's not always practical, but sometimes you have to look at every PC, every driver (Sharp or not) to find the queue that holds this print job. From what you've said, I conclude that the stuck job resides on somebody's PC, not in the printer.
    If you still can't find the job, you can change the printers IP, then change the IP in each of the drivers. Eventually somebody will bitch that they can't print, then you'll find the job. =^..^=
  7. #7
    Senior Tech 100+ Posts
    brewster67's Avatar
    Join Date
    Jul 2011
    Location
    Fairbanks
    167
    Rep Power
    29
    check the job log, that should show what computer the print job came from
  8. #8
    Senior Tech 250+ Posts spanky's Avatar
    Join Date
    Sep 2012
    Location
    Md
    468
    Rep Power
    38
    They may have had a new device installed that is sending information to the IP address that your copier has.
    I have had this happen several times.
    I agree you should supply a new IP address to the copier and add a new port to each of the computers for this address.
  9. #9
    Junior Member CopierShaman's Avatar
    Join Date
    Mar 2018
    6
    Rep Power
    0
    There's actually a couple of possibilities. This is what I'd do:
    1. Check EVERY Server(s)/PC(s)/MAC(s) for uncleared print job(s) sent to SHARP MFP queue.
    2. Check EVERY Server(s)/PC(s)/MAC(s) for uncleared print job(s) sent to SHARP MFP IP via other queue.
    3. Check EVERY Server(s)/PC(s)/MAC(s) for the SHARP MFP printer driver used. Remove and reinstall if necessary.
    4. If 1-3 doesn't help and print job tends to originate from a single source, check your network connectivity/adapter/cable/outlet.
    5. If none of the above solves your problem, repeat 1-4 and check "outside" sources (e.g. remote PCs/MACs, VPNs).
    Hopefully your problem will go away after performing the above.
    PS: If this is a new install replacing a previous MFP, I'd suggest you to use a new IP address, like others have suggested.
    Cheers!
  10. #10
    Trusted Tech 50+ Posts
    Join Date
    Jan 2009
    Location
    Anywho CA
    66
    Rep Power
    32
    If you can catch it the job status while it's printing it may give you the computer or user name sending the print job. Had to do this many times. Had a corrupt rogue print job one time that kept shutting the MFP down. Narrowed it down to a computer with the job in queue, and when I asked the user what they were trying to print, it was a webpage..... with an embedded video. Printers don't like printing videos. :-)
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
