Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Sharp AR-M280U
  1. #1
    Senior Tech 100+ Posts
    Join Date
    Mar 2007
    214
    Rep Power
    37
    Question Sharp AR-M280U
    I have a machine that jams only on duplexing and it jams as it comes out of the fuser and hits the exit roller.I know there is a sensor that is causing
    the problem because the exit roller want come on to eject the paper so does anyone know what i should be looking for because the machine runs one side copies find. Thanks Steve
  2. #2
    Owner/Service Manager 1,000+ Posts
    Sharp AR-M280U
    tmaged's Avatar
    Join Date
    Oct 2008
    Location
    Center of my Universe
    1,763
    Rep Power
    60
    If you're pretty sure it's a sensor, you can run it in aging mode which turns the sensors off. The most common problems on those are sensors going bad since they sit right over the fuser. The one-ways on the turn over. If it has an FN-6 on it, make sure the black gate has the updated pad with the mylar on it. That will cause it to jam only when duplexing.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
  3. #3
    Trusted Tech 50+ Posts
    Join Date
    Feb 2009
    Location
    Fort Walton Beach, Florida
    75
    Rep Power
    31
    I agree with tmaged on this one. If it helps at all, the sensor in the bypass tray (if you have one) is the same as the sensor in the turnover unit. Since it's the heat that weakens the sensor, sometimes you can interchange them and survive until the next one cooks as well.
  4. #4
    Technician 250+ Posts
    Join Date
    Mar 2007
    308
    Rep Power
    38
    You may just want to replace the delivery turn unit. P/N CFRM-1020DS51 It will take a lot of time to swap the sensors as you will need to remove the delivery unit. The turn units don't do good in the fuser heat. They actually warp from the heat.
  5. #5
    Join Date
    Mar 2007
    308
    Rep Power
    38
    I forgot to add-If you want to go with the sensors there are 3, their part number is VHPGP1A73A+-1
  6. #6
    Senior Tech 250+ Posts
    Sharp AR-M280U
    Tech2002's Avatar
    Join Date
    Aug 2008
    Location
    Hartford, CT
    333
    Rep Power
    35
    I agree with mtech. Changing the Delivery Turn Unit will do a few things. You will get the upgraded Unit - (there is a retro-fit) there was a Sensor issue because of grease coating and interfering with the sensor up by the fan, a fan issues because of the heat in that area, and, you will eliminate having to deal with a Sensor you replaced that didn't make the fix. It takes about an hour, or hour and a half to do the job but once it is done - no more painful issues - for you or the client.
  7. #7
    Join Date
    Mar 2007
    214
    Rep Power
    37
    Question
    Thanks for the help but we are not a sharp dealer so does any one know
    where i can order the turnaround unit or the sensors from.
  8. #8
    Sharp AR-M280U
    Tech2002's Avatar
    Join Date
    Aug 2008
    Location
    Hartford, CT
    333
    Rep Power
    35
    Precision Roller is a good start, or a Sharp Dealer, maybe some company not in your immediate sphere of doing business. You can Google the Part # and see what comes up. You may want to see about calling a Remarketer about just buying a machine, one that came off lease, with low mileage. You might get a better deal that way. It can become expensive for parts.
    Remember too, that is an older machine. Got to weigh the cost of repair against looking at new or used for an update.
  9. #9
    Join Date
    Mar 2007
    214
    Rep Power
    37
    I have installed the new delivery turn unit but i am still getting a skew ever once and a while that will cause it to jam,paper skew is the back side copy and it is skew at the registration roller.
  10. #10
    Sharp AR-M280U
    Tech2002's Avatar
    Join Date
    Aug 2008
    Location
    Hartford, CT
    333
    Rep Power
    35
    As another few thoughts, I would look to check feed inside Duplex Unit. That can somethings need cleaning. If this is only happening on Second Side, it would be that feed area.
    I would also check to see if it is one tray or another - or all trays is where this is happening. It could be the a Tray Issue.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
