0
0
Dislikes:
0
MX2300N Call for service code F2-65
What does this service code mean and is it something that we can check on first ourselves?
- Rep Power
- 34
Issues with the process control are you a tech or end user?
I just help out occasionally with IT projects (networking, printers, etc) here at my business. I am somewhere in the middle between a service tech and end user.
- Rep Power
- 34
Well i am not 100% on the exact cause of this as i do not have the correct manual to hand but you will need some technical training/resources to rectify this paticular issue as F2 codes on Sharp kit(as i recall) genarally refers to Process control issues..Si
I don't think it is necessarily the process control, because on this same forum the f2-64 code was listed and it was said to be the Bk Toner supply.
This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment
from http://www.justmanuals.com
Paul@justmanuals.com
F2-65 is the Cyan toner supply abnormality; could be caused by a blocked toner transport pipe from the toner cartridge to the DV unit.
more than likely the toner cart was stored upright instead of flat, and was not shook when installed, hence a large mass of toner on one side of the cart that the stirring parts and augers cant overcome. Or a blocked toner pipe, (although these are very rare for me) Or the drive gears and belts on the rear frame of the developer unit are skipping(or worse broken, if its skipping you will see it in the copy quality, and probably hear it) (Happens more often on black), if they are, a full tear down and cleaning of all bushings bearings and shafts is probably needed (high count machines usually need this around 1.5 mill.) If you aren't a trained tech do not try to do any fixes, other than trying a second well shook cyan cart, past that call a trained tech
Well, it was the cyan toner, and it appeared whoever installed it only took off a piece of the tab. Simple fix obviously, just strange the problem didn't show up until now because that was apparently replaced a long time ago. Thanks everyone.
- Rep Power
- 33
For future reference:
I had the same Code:F2-65. on a MX-5001N copier and the solution was replacing the Waste Toner Box. I tried shaking the cyan several times and it didnt help. Then I noticed that the Waste Toner Box was overflowing cyan so I tried replacing it and when I turned the copier off/on the code went away!
Tags for this Thread
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Bookmarks
