0
0
Dislikes:
0
- Rep Power
- 30
Network error ce-02 on arc 262
HEY HAVING A NETWORK ERROR AND A SHARP ARC 262, ABLE TO PRINT TO MACHINE BUT CANT SCAN FROM MACHINE TO PC. ERROR CODE BEING DISPLAYED IS CE-02, ANY IDEAS??
ps didnt realise caps was on
thanks nick
CE-02 indicates lost communications between the MFP and the PC. In the Network Scanner tools, un-check all profiles and apply. When that comes back, hopefully successfully, re-check profiles and apply again. This should get you going.
If Zootech's advice doesn't work, you can also go to the scanners tab and delete the device, click apply, auto detect for new device, click the box next to the same deveice you just deleted, click apply. I have had to do this when I still got the CE-02 code after updating the profiles.
Good luck.
Bil
- Rep Power
- 30
thanks guys, helpful as always
Tags for this Thread
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Bookmarks
