Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    Senior Tech 250+ Posts
    Join Date
    Aug 2009
    Location
    Sacramento, CA
    285
    Rep Power
    32
    "printer offline" ?
    Hi all,
    I have a customer that has many computers that print to an MX3501 I installed. It's been working great, but all of a sudden there are two computers that show "printer offline" in their printer windows and they can't print. (All of the other printers in the office print just fine.)
    I tried rebooting the computers and the copier - No luck. Tried reinstalling the driver which worked, but all I could do was print the test page and within a couple of minutes, it went back to "printer offline." Tried manually taking the printer offline and it showed: printer offline - offline. Then when I put it back online, it still showed the printer offline.
    Any ideas? Thanks
  2. #2
    Service Manager 1,000+ Posts
    "printer offline" ?
    Join Date
    Mar 2012
    1,220
    Rep Power
    50
    Re: "printer offline" ?
    Are you sure this is not a network issue (I assume there is a router/switch being used)?
    If DHCP is enabled it could be causing IP conflictions.
    Also, it may be useful to note what operating systems the computers that cannot connect are using. And if those computers are using a different operating system than the computers that are working correctly.
    I have never installed a MX3501, but if there is a PCL and a PS driver version, have you tried both?
  3. #3
    Join Date
    Aug 2009
    Location
    Sacramento, CA
    285
    Rep Power
    32
    Thanks Synaux, but these machines have been working fine for several months and there are others in the office that don't have this problem, so I wouldn't think it would be operating system issues, or networking issues.
  4. #4
    "printer offline" ?
    Join Date
    Mar 2012
    1,220
    Rep Power
    50
    Quote Originally Posted by Buddy View Post
    Buddy, often thinking gets in the way . Many times I find myself with a solution that was unfathomable prior to the discovery of the cause.
    MY logic dictates that this is most certainly a network issue (or a permissions issue). The more unlikely scenario is that the computers in question have a virus/something malicious or a driver/hardware issue. (In fact, I almost want to insist on the above options...but...I have been known to be wrong)
    A power outage (however slight) + a crappy router can cause DHCP issues. Consider a static setup for all devices.
    You might want to switch one of the non-connecting computers to a ethernet cable of one of the computers that can print to your MX3501. It is entirely possible you have infidelity in the ethernet line (e.g., bad fitting, rats/mice, etc). AND do this visa versa--this will entirely eliminate any line concerns (but remember, network issues are no solved at this point).
    It its still useful to note the operating systems being used (e.g., Microsoft, Macintosh, Linux, UNIX, et cetera)
    As far as using different drivers--that could be a possible solution/workaround (but you did not reply on this...and Sharp's website keeps timing-out on me....).
  5. #5
    Field Supervisor 500+ Posts DINGO's Avatar
    Join Date
    Nov 2007
    662
    Rep Power
    40
    it seems a IP Conflit.
  6. #6
    Senior Tech 100+ Posts
    Join Date
    Sep 2010
    147
    Rep Power
    30
    Disable SNMP in your driver ( driver property - port tab- configure port - uncheck SNMP)
    Also make sure you dont have any maintenance message on your copier.
  7. #7
    AutoMajical Resolutionist 2,500+ Posts
    "printer offline" ?
    Tonerbomb's Avatar
    Join Date
    Feb 2005
    Location
    Bugaha
    2,589
    Rep Power
    90
    Are you sure that use printer off line is NOT checked in the print que ???
    Mystic Crystal Revelations
  8. #8
    Join Date
    Aug 2009
    Location
    Sacramento, CA
    285
    Rep Power
    32
    Divad2k1 may have won the boobie prize. There is in fact a maintenance message on the display. (I'm waiting on a fuser web.) I'll let you know when I go back out.
  9. #9
    "printer offline" ?
    Lawrence's Avatar
    Join Date
    May 2009
    Location
    NS
    688
    Rep Power
    47
    Divad is right.
    Sim 55-3 SW 9 B5=1
    That will shut down the SNMP on the copier sending the M required notification shutting down the print spooler on that computer.
    Its all shits and giggles until some body giggles and shits...
  10. #10
    "printer offline" ?
    Join Date
    Mar 2012
    1,220
    Rep Power
    50
    Quote Originally Posted by divad2k1 View Post
    This doesn't make sense to me (although I don't doubt it).
    Can you explain this, or is it just one of those unexplainable truisms?
    **edit** just read Lawrence's comment, sorry.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
