Thanks Thanks:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Senior Tech 250+ Posts
    Sharp MX-3201N printer driver installation problem
    Join Date
    Apr 2012
    Location
    Brisbane
    349
    Rep Power
    28
    Hello everywon
    was called out to a client to setup their MX-3201N machine on their windows 8.1 64 bit system, but for the life of me i can't get the printer driver to load (they had tried several times to do so, i noticed their downloads were dated Nov 2014)
    first i tried the installation disk, but the system told me it was an incompatible operating system,,, so i went to the sharp website & downloaded the correct driver for the system, unpacked the zip file & ran SETUP - setup went through the motions & finished stating that the software had been installed, but i couldn't find the printer in "devices & printers"
    pings fine,, browser talks to it,,,
    so, i tried "add printer", the system found the printer, clicked that, system stated it would load the MX-3201N PCL driver & i clicked OK - about 10% into the installation the system stopped with a warning message as follows:
    printer driver cannot be installed
    %1 is not a valid Win32 application
    so, instead i tried "add a device", the system recognised the machine & installed it, it now appears in the "devices & printers" list, but states "driver not present"(or similar)
    uninstalled everything & tried again, same result
    tried "add printer" using manual settings, scrolled through the printers list & found the relevant driver, same error message - tried again, this time i clicked on windows update in the add printer dialogue box,, waited,, clicked the driver,, same error message
    during one attempt i accidently clicked on the driver for MX-3501FN,, it loaded this driver & the printer seems to operate fine, printing emails, PDF's, pictures etc perfectly - i then installed smartdesk & got fax & scan working fine too, i also installed the printer monitor & this appears to be working fine too
    has anyone got any frikken eye-deer why i can't install the MX-2301N driver? and what the heck does that error message mean?
  2. #2
    Join Date
    Aug 2014
    Location
    Trenton, IL
    5
    Rep Power
    0
    Re: Sharp MX-3201N printer driver installation problem
    Check the pc to see if it is a 64 bit operating system.
  3. #3
    Join Date
    Apr 2012
    Location
    Brisbane
    349
    Rep Power
    28
    Quote Originally Posted by JTRAV View Post
    thanks mate, as stated in my original post, it is a windows 8.1 64 bit system
  4. #4
    Legendary Frost Spec Tech 2,500+ Posts
    Akitu's Avatar
    Join Date
    Oct 2010
    Location
    Thompson, MB
    2,596
    Rep Power
    97
    Local resources may have incorrect driver uploaded. My local Sharp gang had the incorrect driver uploaded to the resource website for an MXM232D; intended driver was supposed to be a GDI driver for USB printing but instead it was the SPLC driver that required an IP address, which the machine did not have.
    Call your local Sharp center and consult with their IT guys, the quality control is pretty lax.
  5. #5
    Join Date
    Apr 2012
    Location
    Brisbane
    349
    Rep Power
    28
    Quote Originally Posted by Akitu View Post
    thanks for that tip - will do!!! seeing the original installation disk does not support 8.1, maybe Sharp will provide me a disk, or download, that will
    though i'm wondering, seeing i got the same error with the "windows update" driver, maybe there is some system problem due to their attempts to install
  6. #6
    Senior Tech 250+ Posts DavePo's Avatar
    Join Date
    Jul 2008
    Location
    PA
    300
    Rep Power
    37
    You may also want to check and see if driver signing is turned off. Google it there are directions.
  7. #7
    The New Guy 1,000+ Posts ruben's Avatar
    Join Date
    Oct 2012
    Location
    Bristol, UK
    1,204
    Rep Power
    56
    I never use the CD that comes with the machine, it is always out of date. Instead, download the driver directly from Sharp (http://www.sharp.co.uk/cps/rde/xbcr/...lish_64bit.exe) run the extractor, cancel the setup program, and install the driver manually. If the device is on a network you should have the IP address ready, if it is on USB then run the installer.
  8. #8
    Join Date
    Apr 2012
    Location
    Brisbane
    349
    Rep Power
    28
    Quote Originally Posted by DavePo View Post
    thanks for the pointer - i'll check this out!!
  9. #9
    Join Date
    Apr 2012
    Location
    Brisbane
    349
    Rep Power
    28
    Quote Originally Posted by ruben View Post
    i tried this, i downloaded the driver from the Australian website, then tried the one from the US website, then the UK website - also tried by not using the setup application & installing manually in each instance - also tried the windows update driver,, all came up with the same error
    device is networked, which is why i can ping it & talk to it via a browser
  10. #10
    Join Date
    Apr 2012
    Location
    Brisbane
    349
    Rep Power
    28
    addendum
    seeing the machine is working fine with the MX-3501FN driver,,, is there any reason i shouldn't leave it as is?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
