iR5570 image density uneven
  • brianho80
    • Sep 2009
    • 198
    hi all experts,
    Refer to the below image, top half always print out blur and bottom half look ok but not solid enough.
    i did the below servicing but remain the same print out:
    1, turning the Cylinder at DV tank which seem ok with toner stick on the magnetic roller very even.
    2, drum servicing
    3, adjust Density [2]
    4, adjust Developer from [180] -> [140]
    5, adjust HV-te [+26] and D-Hv-te [+6]
    6, on potential control *even worst* (whole page blur)
    could it be the drum has weaken?
  • nizam
    • Mar 2011
    • 40
    Re: iR5570 image density uneven
    which toner is used
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5013
      Don't skip transfer corona wires.Also check other coronas.
      OEM toner?
      Did you make drum polish with powder?
      • brianho80
        • Sep 2009
        • 198
        i have replace the primary charging, initially i suspect corona wire causing this issue but it remain same
        all the while i using OEM toner but this issue just happen these days.
        • gensys
          • Jan 2011
          • 323
          How many pages the drum has printed it? Most likely it is more 3000000
          The Road will be Mastered by >>> the Going...
          • brianho80
            • Sep 2009
            • 198
            hi canon.tech,
            are you refer to the glass where laser unit will beam of light?
            Zoraldinho, it is neccessary to polish drum with powder because nowaday servicing drum seldom use powder.
            • gensys
              • Jan 2011
              • 323
              Originally posted by brianho80
              hi canon.tech,
              Read This....
              http://www.copytechnet.com/forums/ca...ht-copy-2.html
              • brianho80
                • Sep 2009
                • 198
                hey gensys, thanks for the useful information.
                • arielcanon
                  • Mar 2012
                  • 106
                  Please check laser assy, and check polygon mirror whether clean or not. dirty polygon mirror can cause uneven density.
                  Learning never ends..
                  Never give up, where there is a wheel there is a way..
