KM C353 Vertical Lines on Display
  • ricmartinho
    • 142
    [Electrical] KM C353 Vertical Lines on Display
    Hi everybody!
    I have a problem with a C353 that has flashing vertical lines on display ( ). The machine works well. I have replaced the Operation Panel but the problem remains. I checked the connections of the display and all seems well.
    Any thoughts on this?
    Thanks and Happy New Year!
  • Synaux
    • Mar 2012
    • 1224
    Re: KM C353 Vertical Lines on Display
    MFP board?
    Does it flash on and off too?
    TAUS1000755EN
    • jotunn
      • 629
      Failed PWB-MFP:
      - dry joints in connector soldering
      or
      - under NV-RAM there is SDRAM memory module K4S641632N-LC75 by Samsung (IC207) used as video memory for display and I'm 90% sure that there is a problem - replacing this memory chip should help. Laptop or mobile phones service with hot-air or IR soldering station should do the job without problem.
