Greetings!
I want to print jobs which are over-sized or below normal standard paper sizes by using "Fit" or "fit to print" command. The machine is bizhub Press c1070L. But the print outs are mis-printed. It cuts/trims about 4 to 8 mm from one side. that side can be any side top, left, right, bottom any single side. I have checked every option. I have also tried scaling down and scaling up according to the zoom ratio that best fits or can give good results. I have also checked for the appropriate selection of original size and output size from printing interface. When i hold jobs in HDD, the thumbnail preview shows one side being trimmed or cut off. In the printer preferences menu the thumbnail shows accurate print preview but the output is not what i want. One side is missed from being printed. I do not want full bleed printing.
Is there any setting or adjustment that can help me in getting the desired prints?
Many Thanks,
Copier Nerd
