Results 1 to 10 of 18
    bizhub C224 has C2152 error code
    Samanator's Avatar
    Sep 2017
    Katy, Texas
    422
    35
    Cannot figure this out. The fuser motor turns when the machine powers up. I have checked sensor PS39 and I get a change of state when it is interrupted. I have tried another transfer unit and the code still comes up. I am not that experienced with Konicas so the book maybe saying something I do not understand. I need to get the machine working again. I would be very thankful for any help.
    Service Manager 2,500+ Posts
    Sep 2005
    South Jersey
    3,860
    133
    Re: bizhub C224 has C2152 error code
    I have never seen this code on this model. Actually last time I saw it was a C253 which had a lot of issues with this trans belt code. Since you did everything mentioned in the serv manual then only thing I can think of is re-initializing the machine?
    Field Supervisor 500+ Posts Woxner's Avatar
    Jul 2011
    Felixstowe England
    782
    41
    check IPC3 on printer control board. if you already changed the belt .
    RTFM!! 5,000+ Posts allan's Avatar
    Centurion
    5,397
    152
    Have seen toner cover the retraction sensor. Ended up getting a thin rubber hose to blow it out. To get to the sensor by stripping could take a hour or three.
    The issue was more common on the C360 machines.
    Have changed out control board as well but was probably an ICP.
    There is a clutch i forgot to plug one other time...
    Whatever
    habik's Avatar
    2,015
    59
    Pull the belt out and check if the gear to engage CMY 1st transfer is possible to turn.
    Sometimes just reseating the belt sorts this issue.
    I had it once when replacing CL8 Clutch without taking the belt out of machine. After reseating belt all went away.
    Sent from my Mi A1 using Tapatalk
    Senior Tech 100+ Posts Laserbeam's Avatar
    Aug 2011
    Freiburg, Germany
    152
    27
    Hello at all,
    yesterday I had the same code. Replacing with a new belt didn't succeed, after cleaning PS39 the malfunction still appeared!
    Feb 2010
    1,988
    75
    Quote Originally Posted by Laserbeam View Post
    Hello at all,
    Did you read the post? People pointed at ICP3 and/or controller board
    Aug 2011
    Freiburg, Germany
    152
    27
    yes, I have read the whole post but unfortunately I forgot to ask for the value of the ICP3.
    How many amperes or milliamperes must have a new ICP?
    Certified Konica Expert 2,500+ Posts
    Synthohol's Avatar
    Mar 2016
    North Jersey
    4,987
    217
    none. you check for continuity. its a fuse. ohms not voltage.
    service technician 50+ Posts
    Feb 2018
    Kankakee, ill
    51
    13
    had something similar on a c454 and it was in the fuser drive section with the clutch cl5 that drives the transfer belt, you will have to take the assembly out and inspect for worn items. it is a pain to take out.
