BIZHUB 920 WebConnection, password
Hopefully someone can help me here, I've looked through the threads, but have not found anything yet. I have a bunch of BIZHUB 920s that im trying to access through the web interface. I have other minolta's that i tried the 12345678 password with and it logged in and i changed it. however all the 920's i cannot get in with that password. Is there a different default password for the 920's? I've tried 00000000 and 12345678, 1234, admin, password, pass, (blank). Am i missing something? any suggestions would help. I'm trying to avoid having to go to each machine to do a manual reset.
If I do, how do i manually reset a BizHub 920 Web interface password?
thanks,
- 32
if you have enable account track or user authentication you must log on as administrator the default password is 12345678
konica also use 92729272 and sysadm
reset to factory defaults the controller from the machine panel
and finally re install the firmware of the machine
System Engineer
- 35
Here is the info:
user - ce
password - 92729272
