Bizhub 250 and USB connection
  • mrwho
    Major Asshole!
    • 4299
    [Misc] Bizhub 250 and USB connection
    We're having trouble at a customer's connecting his bh250 via USB to a computer for USB printing. The computer plainly won't recognize the machine. At first we suspected of a bad board, but since we've had this problem with different boards on different machines with different computers.
    To be honest this is the first time a customer wants to use USB with one of these, because since the machine has an ethernet connector most customers just want to use it. But this particular customer needs to use USB, and we can't figure it out.
    Has anyone ever gone through this who can give me some insight?
    Cheers!
    Mascan42
    Ibid
  • ineo+6501
    • Mar 2010
    • 262
    Yes, been through this many times. It turned out to be the USB cable. We tried around a dozen different cables before we found 1 that worked.
    It ended up being the expensive type of cable which you would usually get with a scanner, the type which is quite thick and is shielded at both ends with a ferrite core.
    We stick to them and they seem to work every time. Same goes for the other models which share the same characteristics, 350, 222, 282, 360.
    Don't have a clue why.
    • mrwho
      Major Asshole!
      • 4299
      That makes sense, since we've tried everything else. I'll give it a shot and I'll post some feedback here.
      As for the "why", I suppose an USB connection, like a network connection, must have some sort of error correction. Maybe this model doesn't have it or maybe the one it has is not as robust as other equipments.
      Thanks.
      Mascan42
      Ibid
      • jummamaster
        • Mar 2009
        • 99
        we had have same problem with kyocera FS 116 and a good quality shielded USB cable solved the problem.
        Ricoh Error Codes
        Canon Error 5100
        Canon Error B200
        j
        c
        • emujo
          • Jun 2009
          • 3009
          The 250 is not a "printer" out of the box..must have the enabler installed. Not sure if this affects USB printing, but you might want to look at the spec sheet. Emujo
          If you don't see your question answered in the forum, please don't think it's OK to PM me for a personal reply...I do not give out firmware and/or manuals.
          • mrwho
            Major Asshole!
            • 4299
            Although I know this particular 250 prints (because I printed through it via ethernet) I'm quite sure the 250 prints out of the box. It were the bigger models (420/500 and 600/750) that needed the extra chip.
            Mascan42
            Ibid
            • ineo+6501
              • Mar 2010
              • 262
              You're right mrwho, the 250/350 print out of the box. The 420/500/600/750 needed the IC chip.
              • mrwho
                Major Asshole!
                • 4299
                Solved!
                Tried first with a high-quality cable without success.
                Then, after several tries, driver updating and other stuff, out of the blue I got tired of waiting for the machine to boot everytime I power cycled it, so I turned DHCP off. Hey! It now is detected via USB!
                So, in order for USB to work, DHCP must be turned off! Isn't that cute?
                Just goes to prove my opinion that these machines are basically turds in plastic covers.
                Mascan42
                Ibid
