Results 1 to 10 of 13
    Trusted Tech 50+ Posts
    Minolta 4050 C0040 error
    Sgt. Hulka's Avatar
    Jun 2005
    96
    40
    Any info on this code? I think its a fan but which one?
    Who wants a Hulka Burger?
    Aug 2005
    12
    38
    Re:Minolta 4050 C0040 error
    Replace the fan at the top of the machine. the one that is at the top, near the optical section.
    servmgr2004
    Guest
    Same Issue
    I have the same C0040 code on a Minolta 2050. Can you give me the part number for the fan that is bad?
    Tashima tashima's Avatar
    Apr 2007
    Neuquen
    10
    35
    hi
    for the motor fan the p/n is 9313-1310-61
    but for the expensive cost the technogenius has been created an little trick (available in smarka.com) this consist in blocking the low speed of the fan thats fail not the high, by creating a jumping device in the pwb A please read about these.
    god luck
    Xtechn
    Guest
    I have experienced the same problem with error code C0040 and I ordered the fan p/n listed above, installed it and problem still exist. That part number was for the fan just below the top squirrel cage fan. Does that error code also apply to another fan? Does anyone have it's part number or advise on how to confirm actual problem? I know this copier is old but it has a lot of features not cheap to replace.
    ---Thanks Bob
    Field Supervisor 500+ Posts Luther's Avatar
    May 2006
    crystal lake ,Illinois
    682
    44
    The fan is the transport section suction fan, remove the transport section and the fan is located under it
    field service supervisor 100+ Posts mikeena's Avatar
    Mar 2007
    Pleasanton, CA
    216
    well i will tell you what i have done to fix this. first i believe it is the suction fan motor. its toward the upper part of the machine on the back. if you move the machine away from the wall you will see on the back there is a section were the is some kind of filter. if you remove the pack and take a can error and blow this filter out it should work. be carefull kind of messy plus its glued to the back cover. one other thing to keep in mine is the machine is not to be pushed up against the wall. it needs ventilation for it. Another out point is on the back there is a sensor on the back of the machine that the cover blocks. make sure this sensor works and the cover is on right. failure to do so will cause the same error. I have never replaced the fan myself. I hope this fixes your problem
    mitchl's Avatar
    Apr 2007
    Tampa
    499
    43
    Quote Originally Posted by mikeena View Post
    I cant believe you remembered the back cover sensor gives you the same code, as soon as I read it it sort of came back to me.......... To much Grey Goose over the years I guess, but good call!
    mdw
    Guest
    Minolta CF-1501 Error Code C0040
    Somebody please help me!!!!!!!!!
    copytechman's Avatar
    Nov 2008
    Barrie, Ontario
    909
    44
    As others have said suction fan motor M4 failure to turn... been there, done that, quite famous for bearing failure and not spinning upto speed, its on the back right below the optics cooling fan, looks like a miniature blower fan.. Jeez I used to collect these! Good for cooling projects on a speed that works (usually it was the low speed that stopped working properly) Replaced many!
    Regards and good luck!
    A!
    For the CF1501:
    C0040 Fusing Cooling Fan Motor
    2’s failure to turn
    A Fusing Cooling Fan Lock signal is detected for a
    continuous 3-sec. period while Fusing Cooling Fan
    Motor 2 is turning.
Similar Threads
  1. Minolta 2050 error EM2
    By Diana Goerz (Specialo@telusplanet.n in forum Konica Minolta
    Last Post: 08-15-2009, 01:40 PM
  2. HP 4050 52.0 error code
    By Frank in forum HP
    Last Post: 04-11-2007, 06:06 PM
  3. Minolta Bizhub C350 print error
    By copro in forum Connectivity
    Last Post: 02-19-2007, 03:12 PM
  4. minolta DI620 c1441 code
    By dqydj in forum Konica Minolta
    Last Post: 11-30-2006, 03:18 PM
  5. Minolta DI30 Di-30 error C-510 C-0210
    By okin in forum Konica Minolta
    Last Post: 01-19-2006, 06:35 AM
