I ran 25 pages without a jam before starting. Look in the jam log and
the only code was E3C0. So I pulled the tandem supply feed head and
cleaned and lubed and scuffed up the shafts and tested. It was jamming
once every 25 pages. At this point it look as though the paper crashed
in the duplex diverter gate. The code was E020 fuser exit. I replaced
the upper roller and web. Checked out the fuser section. It showed wear
but all the gears were meshed.
Ran some more and it kept crashing into the gate. With code E5A0, did not
reach exit sensor and indeed it crashed on the gate. Took the spring off
the gate then ran 225 without a jam.
On my way out the door, this guy comes up, puts two pages in the doc
feeder. It jams out the side exit with a code of E570. And he was not
doing a duplex job.
I have cleaned the rollers in the paper path, checked to make sure there
was even pressure on the fuser output rollers. I think I replaced the
fuser exit sensor a couple of months ago. The last thing it did was jam
with a sheet coming out of the side exit about 3". Code E570.
And that was just after I had run 25 pages.
I noticed that the side exit has it own drive motor, has anyone replaced
it for jams? I have checked the sensors with the input test. They work.
DR
Bookmarks
