Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Technician 50+ Posts
    Join Date
    Sep 2008
    Location
    Bulgaria
    62
    Rep Power
    32
    xerox 510 firmware update
    Hi, I have Xerox 510 wide format for service and it freezing.. I want to update the firmware through COM port (not through controller) but I don't have the service CD. Is there anybody why has got this CD or why knows link for download.
    Thanks!
    copier and printer service technician
    The perfect gift
  2. #2
    Service Manager 1,000+ Posts
    adriansto's Avatar
    Join Date
    Nov 2007
    Location
    Somewhere in Europe near Black Sea
    2,239
    Rep Power
    71
    There is a service cd for that. Your email is ?
  3. #3
    Join Date
    Sep 2008
    Location
    Bulgaria
    62
    Rep Power
    32
    email
    My e-mail is vale24@dir.bg
    Thanks!
    The perfect gift
  4. #4
    Senior Tech 100+ Posts
    Join Date
    Mar 2011
    Location
    Baltimore, MD
    167
    Rep Power
    28
    You did not provide enough information about what version of controller to answer the question properly. What version controller are we talking about? Did you get your answer? If not, please respond.
  5. #5
    Join Date
    Sep 2008
    Location
    Bulgaria
    62
    Rep Power
    32
    xerox 510
    Hi, The problem is not solved yet and is: the machine gives you "ready to print", you can see everything on the WEB interface, you can do internal print test, BUT you can't print anything from the PC. It seem that it has communication only in one direction....
    Any Ideas!
    The perfect gift
  6. #6
    Join Date
    Mar 2011
    Location
    Baltimore, MD
    167
    Rep Power
    28
    Not being able to print to the machine would indicate a network set-up or print driver problem. Go into the WebPMT, to configuration, and then Upload a File. Browse to a TIF image, and select Upload. If the print works, then there is a problem on your work center driver setup.
  7. #7
    Join Date
    Aug 2006
    1,653
    Rep Power
    57
    in print driver properties change raw port number to 2000 or lpr queue name to RAW.
  8. #8
    Join Date
    Sep 2008
    Location
    Bulgaria
    62
    Rep Power
    32
    I even can't print anything from WEB interface (when you get access to the machine by typing the IP address )- test print, full test or whatever you want... NOTHING. the problem is somewhere in the machine because i did test with another controller - the same story...
    The perfect gift
  9. #9
    Join Date
    Mar 2011
    Location
    Baltimore, MD
    167
    Rep Power
    28
    It would have helped to mention having tried the other controller from the beginning.
    You are correct then, the problem has to be in the printer. Sounds like you are looking at the main board. Can you print an internal test pattern going through diagnostics?
  10. #10
    Join Date
    Sep 2008
    Location
    Bulgaria
    62
    Rep Power
    32
    Yes, I can print only internal print from the panel..
    Thanks!
    The perfect gift
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
