Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
  1. #1
    jk_nvs
    Guest
    System Software for FIERY X-12
    Need Help regarding installation of Fiery X-12.
    I want to know which type of Operating software or Softwares are installed in Fiery X-12.
    Recently I have problems while printing in Xerox DC-12 through
    FIERY X-12, on the LCD display of FIERY - only
    Loading.... appears and fiery is stuck off on that position.
    It Seems that Hard disk of FIERY may be damaged or corrupted.
    SO I want to know the procdure to install the new harddrive and load its system softwares.
    It will be a great help if anyone provides me the procedure to do so.
    Thanks.
  2. #2
    Join Date
    Oct 2007
    3
    Rep Power
    0
    To restore from backup do the following:
    1) Power down the Fiery and wait 10 seconds.
    2) Press and hold the 4th key on the right side on the UI (user interface) and power on the Fiery.
    3) Continue to hold the 4th key until the UI reads "Install Software", "Restore Backup", "Install Option" and "Start System".
    4) Select "Restore Backup"
    5) Select "Yes" at the following question "Restore backup configuration?"
    6) This will take approximately 15-20 minutes and the Fiery will reboot 3-4 times.
    7) Once the Fiery comes up to Idle you will need to "Run Setup" and reconfigure the settings.
  3. #3
    jk_nvs
    Guest
    Thanks for help friend but already tried the way described.
    Thank you very much friend for your reply.
    But, I have already tried the same procedure but no way has been found.
    I have heard from the friend, that for solving this problem. I have to
    reinstall the drivers and software in the Harddrive of the Fiery. If you have the Ghost Image of the Fiery X-12 Version 1.5 SP 2 and if you can send it to me so I will restore the image on my New Drive.
    Or Otherelse If you have any other way, it will be greatly appreciated.
  4. #4
    Service Manager 250+ Posts
    Join Date
    Mar 2008
    Location
    Auckland
    289
    Rep Power
    35
    We have tried to pull out the HDD of the x12 and connect it to a pc. Then use a BOOT record repair software in UNIX mode to repair the MASTER BOOT RECORD of the HDD. The software is available FREE from the internet, just google search and choose the appropriate software. Saves you time from loading the system software off 2 CDs.
  5. #5
    dksrinivasrao
    Guest
    how to repair the boot sector using unix mode can u ecplain
    i'm also facing same problem
  6. #6
    Service Manager 1,000+ Posts
    Join Date
    Aug 2006
    1,639
    Rep Power
    57
    patch in attachment
    change extension from doc to ps
    Attached Files Attached Files
  7. #7
    Join Date
    Mar 2009
    Location
    singapore
    266
    Rep Power
    0
    x12
    this is deu to the harddisk problem you can get one workerable and clone the hd from the working one and put in is should work for you thanks !!
  8. #8
    Senior Tech 100+ Posts
    Join Date
    Mar 2009
    Location
    lahore , punjab
    232
    Rep Power
    0
    fiery x 12 system software
    dear friends ,
    i have fiery x12 system softwae cd and i can send to you but i also need fiery x12 system software cds for bios verson 1.1 because after reinstallaion of software i am facing problem invalid license message.
    so if anybody have system softwar cds with bios v 1.1 then pllease send. ktxerox@gmail.com.
    Quote Originally Posted by johnner66 View Post
  9. #9
    Join Date
    Aug 2006
    1,639
    Rep Power
    57
    bios versions are 1.41 and 1.43
    but you can not install bios with non working fiery.
  10. #10
    CopyCat
    Guest
    Quote Originally Posted by jk_nvs View Post
    Greetings,
    Your hard drive may have some bad sectors that may be correctable.
    I've used SpinRite from GRC.com to correct non-electrical problems on many IDE and SATA hard disc drives over the years.
    You'll have to pull the hard drive from the Fiery and install it in an Intel based PC, then boot the PC from the SpinRite CD or floppy disk. Under no circumstances try to use Windows to try and repair the drive. It will just make it worse.
    SpinRite is $89 [ GRC|SpinRite 5.0 to 6.0 ]
    Be warned that there are some files that appear to be SpinRite "floating" around on the Net, but are really a virus or trojan.
    Let us know if you're successful or not.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
