Foxelli Headlamp!!!
  • qbert69
    • Mar 2013
    • 1152
    Foxelli Headlamp!!!
    Hey Everyone!
    Just wanted to let you know I found a Great Headlamp!...Made By Foxelli!:
    Rechargeable Headlamp | Foxelli
    Extremely Comfortable and Lightweight!....USB Rechargeable so you don't have to buy any more batteries!....charge it while on your way to a service call...or when you get home!....100 hours runtime on low mode, which I found perfect for close tech work on copiers!....Plus it has a diffuser to slide over the light to broaden and soften the light!
    I just couldn't believe the price from Foxelli--$29.97 w/free shipping in the US!....WoW!
    Below are some personal pix I took!:
    Below is an example of using the light...nice and diffuse...not too harsh...perfect for seeing the subject material and taking a picture with your mobile phone!...BTW, what you are looking at is the electrical connections of the paper feed units on a Ricoh B&W 50+ CPM MFP!
    Here are some pix of the Foxelli Headlamp that I took myself below!:
    This is the downward facing micro USB charge port on battery pack on the rear of the headband!...It is facing downward...just in case you forget to reseal it with the cap, it won't collect water if you go out in the rain!
    Here is a closeup of one of the clips holding the power wire to the headband....it has a positive click feature so the power cable stays put!:
    Below you see the black durable strain relief that holding the power cable and to the left, you see the battery charge indicator!:
    An SOS whistle attached to the headband...."Just in Case"!:
    View of Light Diffuser which slides down over the light to broaden and soften the light!:
    View of the Diffuser slid up with the focused spotlight lens visible!:
    Below, on the side of the light unit, you see the power/multi-mode change button!:
    On this side of the light, you see another durable strain relief for the power cable!:
    Anyway, I hope you folks liked my pictures!
    For me, my headlamp (Foxelli now!) is probably one of the most, if not THE MOST valuable tool I have in my tool bag!...If I can't see what I am working on--handsfree (not holding the light) I can then see AND use both hands to do the job quickly and efficiently!
    So If anyone has any questions about this headlamp, add to the thread!...I'll try to respond as accurately and quickly as possible!
    CHEERS
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • 23008
    Re: Foxelli Headlamp!!!
    It looks very handy, but just a little geeky. =^..^=
    • qbert69
      • Mar 2013
      • 1152
      Not at all geeky!...especially when it keeps you from getting you fingers caught in a belt drive!
      PS--My headlamp previous to the Foxelli was more *geeky*!
      • Lagonda
        • Aug 2008
        • 1649
        But surely a good tech should be able to work with his eyes shut?
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          cool ? yes! but a little pricey........... I've bought a couple headlamps at the local chain stores with a pack of AAA bats for $15 or less and got at least a year out of it before I had to buy more batteries.....................
          Mystic Crystal Revelations
            • 37490
            I use a Utilitech LED flashlight. 1 1/4" diameter, 4" long, three AAA batteries. Small enough that I can turn it on and position where it provides light where need it. I buy them at Lowes. List online as $9.97. I usually find them in the store for under $6.
            • Iowatech
              Not a service manager
              • 3930
              After you use it for a while, I'd be interested in hearing how durable the on/off switch is. I'd like LED lights a lot except the switch always fails early for me.
              Of course that is likely my fault. For troublesome calls, telling the people exactly what is happening can be unproductive. Sometimes when that happens, I turn big, green, and uglier on the way out to the car and things I find that are of questionable durability get broken.
              • allan
                RTFM!!
                • 5462
                Petzl Tikkina.
                Cheap and strong. Good enough for everyday use.
                Whatever
                • theengel
                  • Nov 2011
                  • 1784
                  How the hell you gonna look cool wearing one of those things?
                  • qbert69
                    • Mar 2013
                    • 1152
                    Originally posted by allan
                    Petzl Tikkina.
                    I did read that the Tikkina can use rechargeable Ni-Mh batteries...but the question is, can you recharge the batteries while they are installed???
                    • qbert69
                      • Mar 2013
                      • 1152
                      Items of "questionable durability" should not require any intervention to break!....they should only fail from normal use!...LOL!
                      The switch on the Foxelli is slightly recessed and out of the way so it can't get "accidentally" damaged!
                      • qbert69
                        • Mar 2013
                        • 1152
                        I had to do that when I was a photo lab technician!...I had to change photo paper roll cartridges inside of a black bag!
                        Been there, dun that!
                        • qbert69
                          • Mar 2013
                          • 1152
                          I *HATE* dealing with batteries!!!...especially if they are loose!...imagine if your mobile phone required loose batteries to function!....that would be hell!..thank goodness you can recharge with a USB cable!
                          I got a bunch of spent batteries floating around in the back of my vehicle that don't have enough power for my headlamp (Coast Headlamp)....I have built a Joule Thief which I can use to power some LEDs:
                          Joule Thief - Google Search
                          Simple and Fun Little Project!
                          These Guys Explain the Joule Thief really well and do some cool stuff too!:
                          Weekend Projects with Bre Pettis: Make a Joule Thief | Evil Mad Scientist Laboratories
                          PS--Joule Thief on eBay!:
                          joule thief | eBay
                          • Tonerbomb
                            • Feb 2005
                            • 2589
                            It must come with a pocket protector and a ruler.........................
                            • ZOOTECH
                              Senior member of CRS
                              • 3375
                              Hey, that hit a soft spot, but it wasn't a ruler - it was a slide rule.
