Network OS /Real Time OS
  • Limme51
    A network operating system (NOS) is a computer operating system .system that is designed by Professional Web Design companies primarily to support workstation, personal computer, and, in some instances, older terminal that are connected on a local area network (LAN). Artisoft's LANtastic, Banyan VINES, Novell's NetWare, and Microsoft's LAN Manager are examples of network operating systems. In addition, some multi-purpose operating systems, such as Windows NT and Digital's OpenVMS come with capabilities that enable them to be described as a network operating system.
    A network operating system provides printer sharing, common file system and database sharing, application sharing, and the ability to manage a network name directory, security, and other housekeeping aspects of a network.
    A real-time operating system (RTOS) is an operating system that guarantees a certain capability within a specified time constraint. For example, an operating system might be designed to ensure that a certain object was available for a robot on an assembly line. In what is usually called a "hard" real-time operating system, if the calculation could not be performed for making the object available at the designated time, the operating system would terminate with a failure. In a "soft" real-time operating system, the assembly line would continue to function but the production output might be lower as objects failed to appear at their designated time, causing the robot to be temporarily unproductive. Some real-time operating systems are created for a special application and others are more general purpose. Some existing general purpose operating systems claim to be real-time operating systems. To some extent, almost any general purpose operating system such as Microsoft's Windows 2000 or IBM's OS/390 can be evaluated for its real-time operating system qualities. That is, even if an operating system doesn't qualify, it may have characteristics that enable it to be considered as a solution to a particular real-time application problem.
    In general, real-time operating systems are said to require: multitasking, Process threads that can be prioritized and a sufficient number of interrupt levels
    Real-time operating systems are often required in small embedded operating systems that are packaged as part of micro devices. Some kernels can be considered to meet the requirements of a real-time operating system. However, since other components, such as device drivers, are also usually needed for a particular solution, a real-time operating system is usually larger than just the kernel.
