Bad Paper?
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    Bad Paper?
    I am pretty sure that over the years I have been doing this, I have only blamed the paper for the machine 's problem a handful of times. I always believed that too many techs use paper as an excuse, when the machine could have been fixed. I have had customers tell me that another tech told them it was the paper, and I would smile and tell them to watch me fix it, because I am a real tech. If the paper is bad, you should be able to see it and prove it.
    On Ft. Bragg, they are required to use recycled paper. The law requires government to use recycled, even though it cost a lot more. My state is VERY humid. Usually when I am showing the customer how to identify bad paper that is too humid, I can point to the ends curling up after going through the fuser, and the finished product looking like laundry that has not been ironed. The big thick separator fingers that Konica now uses, have been great, and rarely fail.
    THE ISSUE...
    Over the past couple of months, 2 of my Bizhub 600's have turned into a pain in my ass. The first one is my most used machine and has about 3 million on it. It sits in what was an old motel room about 6 feet from the door that seems to be open all day long. I fought it and changed stuff and made adjustments until it quit. I assume it quit, I had a second machine moved out there to take off some of the load, it may be dead and they just haven't called, but when last I was there, it ran.
    Problem child #2 has been having this issue for about the same amount of time. I would get the call for it being jammed, find one in the cleaning section, remove it and it would run fine for a while. This machine is in a modern building, at the end of a hall, about 50 feet from a door that is open most of the time. On this machine, the total meter is 750,000. The transfer sep unit only has 3000 on it. The drum sep fingers were traded with a working machine. I have jacked up the manual voltage adjustment to the max.
    While I was there on Tuesday , I just had a gut feeling it was paper. Opening fresh paper of theirs did no good. It would not pass 3 sheets without trying to eat one. I went to the shop and got a ream of our paper, Members Mark from Sam's Club, went back and ran 25 copies. I put their paper in and it sucked one up. I cleared it and put mine back in, ran 50 copies. Put their paper back in and it jammed. Traded it out again and it ran with my paper.
    Now here is part of the problem. Why is this underused machine doing this? The paper shows none of the usual signs of being crappy. It comes out of the machine crisp and flat, no curled corners. Do any of you folks have a magical set of numbers to set your voltages too on a Bizhub 600 to run shitty paper, because tech support was no help. I still don't think it is all in the paper because I have dealt with much worse.
    • 22927
    Re: Bad Paper?
    The following study was done in 1927, long before the appearance of electro-static photocopying, but is still pertinent.
    It's an interesting read.
    From a practical aspect, the only thing I know to do is to microwave a small batch of paper. Most offices have a microwave somewhere big enough for letter size paper. The time will depend on how much paper you're nuking. Trial and error. I wouldn't try for a whole ream. The most I'd go for is 50-100 pages at a time. Yes, it sound impractical, but it's all I've got. =^..^=
    • fixthecopier
      ALIEN OVERLORD
      • 4714
      Re: Bad Paper?
      Thanks for the data, that is just the kind of geeky stuff I like. I had a guy in Psy-Ops tell me he made a paper incubator in the jungle by installing a 40 watt bulb in a metal supply cabinet.
      I am thinking I have missed something. I have 3 more of same machine in this building, using same paper, with a lot more copies on them, and have no issues.
        • 22927
        Re: Bad Paper?
        I like the light bulb thing.
        I'd take a metal cabinet of some sort as a base. Then drill a bunch of 1/8" holes within a 1/2 round shape. Then I'd mount a half round shutter that can be rotated to cover all to none of the holes, as desired, to regulate air flow. I'd do the same thing on the bottom of the cabinet. Then I'd mount two 40 watt bulbs in the bottom portion of the cabinet on a dimmer. In that way you can install larger or smaller bulbs, turn up or down the heat source, and regulate the airflow with the shutters.
        Sort of a metal version of the fruit dehydrator in my kitchen.
        I made a hat dryer on the same principles, just conical at the top to fit the inner band of my hat. A 15 watt bulb dries the hat overnight, and warms it to ~140F. It's a nice way to start out a cold wet morning.
        The 40 watt bulb was a bit too much. No flames, but the hat was ruined. =^..^=
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          Re: Bad Paper?
          [ATTACH=CONFIG]21068[/ATTACH][ATTACH=CONFIG]21069[/ATTACH]
          Very creative BC! Now if your already wiring in AC, how about adding a humidastat , a step down transformer ( to power the humidastat and relay) and a relay ( to control the lamps) so you can regulate the humidity in the paper. If you dry it out too much you know you will have a static problem.
          Mystic Crystal Revelations
            • 22927
            Re: Bad Paper?
            Originally posted by Tonerbomb
            Very creative BC! Now if your already wiring in AC, how about adding a humidistat , a step down transformer ( to power the humidistat and relay) and a relay ( to control the lamps) so you can regulate the humidity in the paper. If you dry it out too much you know you will have a static problem.
            Sounds great. ~35% humidity inside the cabinet would be perfect to achieve 3.0% in the paper. =^..^=
            • fixthecopier
              ALIEN OVERLORD
              • 4714
              Re: Bad Paper?
              If I go back tomorrow and determine that my paper runs better than theirs, and there is nothing else I can do to the machine, and I know there is no way to get the customer to dry out the paper, I have a solution for the short term. I will trade out my reams for the ones they would put in that machine. The law says that they have to buy recycled, but it does not say the copy guy can't swap it out after they buy it. At least until I can think of something else.
              • JR2ALTA
                • Feb 2010
                • 2028
                Did you really throw the other tech under the bus in front of the costumer ?
                cringe
                • Iowatech
                  Not a service manager
                  • 3930
                  Re: Bad Paper?
                  If you've already tried this, sorry about that.
                  Still, paper can sometimes be run more effectively if you switch it from LEF to SEF. And, while I haven't seen this for a while, sometimes if you load the paper with the seam in the ream wrapper up it works better, too.
                  Kind of depends on the grain of the paper and the observed curl after it comes out of the fuser.
                  As far as the paper drying cabinets are concerned, if you want to do that get a dead fridge and put a hundred watt bulb in it. You can also keep arc welding rods dry in that.
                  • fixthecopier
                    ALIEN OVERLORD
                    • 4714
                    Re: Bad Paper?
                    cringe
                    If you are referring to my comment about them throwing off on paper, then YES I DID. Anytime a customer tells me that, it should be followed by "And then he proved it." 9 time out of 10, that excuse is used by a tech who needs more experience.
                    • fixthecopier
                      ALIEN OVERLORD
                      • 4714
                      Re: Bad Paper?
                      Problem is, there is no curl. Comes out as flat as any premium paper, but mine runs and his does not...in only one machine.
                      • BLADE
                        former propeller tester
                        • 478
                        Re: Bad Paper?
                        maybe you need to look from a static angle (static brushes, earths , blocked airflow)
                        • fixthecopier
                          ALIEN OVERLORD
                          • 4714
                          Re: Bad Paper?
                          That's what I am thinking, I believe I have tunnel vision and am stuck.
                          • Darren King
                            copiertech
                            • 652
                            Re: Bad Paper?
                            Have you opened the front door and watched the paper to see what it is doing? Have you removed the drum claw assembly to check for toner in the solenoid, it will slow down the drum claws and allow paper to follow the drum into the cleaning section. Maybe one of the drum claws is out of position.
                            Hope this helps.
                            Darren
                            • MR Bill
                              • 532
                              Re: Bad Paper?
                              I delivered a BRAND NEW machine to a customer. Copystar CS-2221. I put customers paper in the cassettes and it jammed about every 7 or 8 copies when I was doing the demo. The machine worked great in my office. It was their paper causing the problem. And it was not recycled. I exchange their paper and machine worked fine. Made the sale cause they were a long time customer. I could not see anything wrong with there paper. Nothing at all.
