FOOD
  • igi
    • 1507
    #106
    Re: FOOD
    Originally posted by Debs1964
    Pill take the strawberries and champagne, but you can keep the caviar...YUK lol
    i love lamb, especially when it's been slow cooked and melts in your mouth
    well the way you described it
    it does sounds very-very tasty
    • allan
      RTFM!!
      • 5462
      #107
      Re: FOOD
      Just had one of these
      Whatever
      • igi
        • 1507
        #108
        Re: FOOD
        [ATTACH=CONFIG]28353[/ATTACH]
        and what kind of edible pen is that
        • NeoMatrix
          Senior Tech.
          • 3513
          #109
          Re: FOOD
          I got as far as the green blob. First glimps I thought it was a frog missing a couple of legs.
          Should have gone to spec-savers...
          • allan
            RTFM!!
            • 5462
            #110
            Re: FOOD
            If you add legs Mr Freeman from HL will shoot at it.
            Whatever
            • igi
              • 1507
              #111
              Re: FOOD
              if you add legs,
              some people might take it for a date
              • MjarbarV2.0
                Adeptus Mechanicus Magos
                • Feb 2014
                • 68
                #112
                Re: FOOD
                Chinese Leaf parcels stuffed with Thai Pork mince
                Prep time 15 minutes, cooking time 20 minutes, Serves 5
                Ingredients:(I love bean sprouts so always use 100g but 75 can be enough!)
                Preparationwhy not? Steaming vegies is a lot healthier than boiling and is good for fish as well!), wrap in foil, place on a wire rack over water in a roasting tray and cook over a high heat for 15-20 minutes or until cooked through.
                Serve with rice or noodles and enjoy. YUM!
                The impossible is easy - miracles take a little longer
                Let us not talk falsely now, the hour is getting late.
                • Akitu
                  Legendary Frost Spec Tech
                  • Oct 2010
                  • 2595
                  #113
                  Re: FOOD
                  So it would appear I've been missing out on most of this thread. On the topic of hot sauce, this is the stuff I use
                  That stuff tops out at 357,000 SHU, or approximately the power of 71.4 jalapeno peppers. I typically only use it directly on my chicken wings when I decide to do up home made hot wings; else I'll dilute it to 1 parts 357 sauce, 10 parts (insert hotsauce). Unfortunately as you climb the scoville ladder, things often end up sacrificing flavour for heat. This stuff falls on the other side of the flavour fence so by itself it always seems to be lacking.
                  My usual go-to hot sauce is Frank's xtra hot or Frank's Buffalo sauce. I've always liked the vinegar-y sauces and always love hot wings any time, any place I can get 'em.
                  • igi
                    • 1507
                    #114
                    Re: FOOD
                    when too much heat is too much?
                    • Akitu
                      • Oct 2010
                      • 2595
                      #115
                      Re: FOOD
                      The Blair's Reserve line is too much. Take this for example, the infamous 2 AM Reserve Extract. https://www.mohotta.com/product/blai...erve/Hot-Sauce
                      This product is rated at 2,000,000 SHU or just over 5x as hot as the stuff I consume. THAT is too hot. There is no flavour in that, only burning.
                      • igi
                        • 1507
                        #116
                        Re: FOOD
                        my judj
                        I rate them purely by strength and taste
                        if it burns me twice, then I try to stay away from it
                        • michaelc
                          Field Tech
                          • Mar 2011
                          • 590
                          #117
                          Re: FOOD
                          Steak cut chips, beans and sausages (Lincolnshire)
                          It didn't say that I couldn't do it in the manual.
                          • NeoMatrix
                            Senior Tech.
                            • 3513
                            #118
                            Re: FOOD
                            If you read the label it probably says food additive 802, in laymans terms rougly translates to : ate-hole-two ,which feels like hydrochroic acid coming out your rectum.
                            Don't use dunny paper to clean up the aftermath as it's combustable, use a damp cloth in case you need to stamp out a fire.
                            That stuff sounds like it should come with a biohazard license an no smoking warning before using it on your food.
                            • igi
                              • 1507
                              #119
                              Re: FOOD
                              there is an easier solution.
                              just store you paper in the freezer.
                                Re: FOOD
                                I have tried some Hot Sauce, cannot remember the brand name.
                                My mate Brian asked me and Steve if we wanted to try it, yes we are grown men, some may even call us adults.
                                A drop was placed on a spoon and we had a drop each, Brian said we wouldnt need any more than that with a snigger.
                                At first we thought this aint that hot.
                                Five minutes laster the heat starts to get worse.
                                Ten minutes later we start sweating.
                                Fifteen minutes later I cannot speak comfortably.
                                Four litres of milk between the two of us didnt releive the pain much.
