Ricoh 2090 ADF false jam?
  • iiixtheory
    • Mar 2025
    hello copytechs!
    im having trouble finding the cause or source of this problem. A Ricoh 2090 is giving me a false jam message AFTER it successfully feeds 1-10 pages thru the ADF. The error reads as " clear jam in P1 section" which is the adf entrance.
    and tips or parts that may need replaced would be greatly appreciated
  • iiixtheory
    as it turns out there are several sensors in the adf area.
    i went thru and cleaned all 7-9 sensors that i could find.
    while doing so the machine popped a sc-705 code which after searching the web pointed me in the direction of the adf lift tray.
    once i thourougly cleaned the adf lift tray sensor the problem seemed to resolve itself!
    ill probably replace the sensor on the next service cal just to play it safe...
